my shee got beat up
my shee 87 4 mil long rod stroker 80 over milled head i think 25 thousandths with spacer alot of port work 2 - 33 pwk pro flow with foam filter timing my builder said around 4-7 not sure new set up just built 22-11-9 hole shots with 13 - 39 gearing now my buddies quad 2006 with port work from same guy head milled same guy 25 thousandth 20 over power lid plus k and n stock gearing stock tires 340 main jets stock carbs i get him alittle out the gate he catches rite up and passes me not sure if my carbs are set up with the rite needles trinity says i should put diffrent needles and jets anyone know off hand and what the fuck happened we both left same gear and ride the same so its not rider to rider
ur clutch could have been slipping. i was runnning an '88 motor bored .60 over and got beat by my buddy whos is still stock bore with the almost same setup as mine. id beat him out, but b/c my clutch was slipping so bad, the motor just rapped to the motor and i was barely gaining speed
new clutch with hinson basket heavy duty springfeels like its grabbing
What is your jetting?
Main Jet Size
What needle and Clip Position
Pilot Jet
Air Screw truns out
It might also be your porting. When you have your cylinders ported for a stock crank they raise the transer port hight. When the builders port the transfers for the stock crank they are to high for the stroker crank. I know you said that you have a spacer plate that is what I am not to sure of. Most builders dont run them. They just cut the head for the stroker.
