Camber and Caster
Bairdy13
use a tape measure... messure the front and back and set them the same .. then measure top and bottom and set them about 1 inch less on top ...no special tool is needed
this will do caster camber and tow picth so then you should be rdy to go
Edited by Bansh-eman
Good explanation. :thumbsup:
Yeah, what he said. :thumbsup: I put ratchet straps from the bars to the pegs and tighten them down once the handlebars are straight, then I adjust everything. I also like to put the bike up on it's grab bar and eyeball everything just to make sure it's good since you see a different angle when it's on the ground.
