nicktoney Posted January 29, 2007 Report Share Posted January 29, 2007 hey, im getting my motor together today, i had a hold up over the weekend... anyways, im to the nut on the clutch... how do i get that torqued to 66ftlbs with out buying that special clutch holding tool????? anyway?? if so, could i get a pic? thanks guys Quote Link to comment Share on other sites More sharing options...
man27 Posted January 30, 2007 Report Share Posted January 30, 2007 hey, im getting my motor together today, i had a hold up over the weekend... anyways, im to the nut on the clutch... how do i get that torqued to 66ftlbs with out buying that special clutch holding tool????? anyway?? if so, could i get a pic? thanks guys I put 2 bolts in the clutch housing so my brother could hold it with a screw driver or if you have a old clutch set drill and bolt a steel and friction plate together to lock the primary gears together but make sure the bolts are long enough to pull the plates out when you put them in. :beer: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 30, 2007 Report Share Posted January 30, 2007 its been awhile that i have done it but you should be able to hold it with the inner hub tool.... wedge it on the ground and torque it... if al else fails juts tighten it down as much as you can by holding the basket and call it good... you should have the little thing on there that bends over to hold the nut from spinning Quote Link to comment Share on other sites More sharing options...
woodro77 Posted January 30, 2007 Report Share Posted January 30, 2007 i put mine on with impact gun on lowest setting , never had a problem with it Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted January 30, 2007 Report Share Posted January 30, 2007 2 pieces of flat steel, a grinder, and some bolts. I made my own tool. Not to hard, works great. Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted January 30, 2007 Report Share Posted January 30, 2007 If you use the impact be careful, I have seen someone bump it once to much and strip the nut.I use a fiber and a steel plate screwed together and place a penny between the gears to keep the basket from turning as i torque it.Once it is torqued I turn the basket slightly the other direction to remove the penny.Copper is soft so it won't hurt the gears. Mark Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 30, 2007 Report Share Posted January 30, 2007 If you use the impact be careful, I have seen someone bump it once to much and strip the nut.I use a fiber and a steel plate screwed together and place a penny between the gears to keep the basket from turning as i torque it.Once it is torqued I turn the basket slightly the other direction to remove the penny.Copper is soft so it won't hurt the gears. Mark id say do it this way, iv heard many ppl do it this way and have had no problems... i have a tool so i juts used that Quote Link to comment Share on other sites More sharing options...
gregbowler Posted January 30, 2007 Report Share Posted January 30, 2007 I just used a folded up rag stuffed in the gears. worked for me Quote Link to comment Share on other sites More sharing options...
nicktoney Posted January 30, 2007 Author Report Share Posted January 30, 2007 but doesnt that inner hub spin by itself inside the big clutch basket? so stopping the gears wouldnt do much would it? i got that primary gear nut torqued with a home made tool.... but the clutch nut?? Quote Link to comment Share on other sites More sharing options...
sheefreak Posted January 30, 2007 Report Share Posted January 30, 2007 Yes, the inner hub will just spin w/the rag or penny. You should really get the proper tool to do this. I think the flywheel/clutch hub tool is like $20-$30 max. I have seen it done by screwing two screws into the hub and holding w/a screwdriver as mentioned above. But I have seen someone break one of the thread mounts on the hub doing this as well. Quote Link to comment Share on other sites More sharing options...
87_shee Posted January 30, 2007 Report Share Posted January 30, 2007 but doesnt that inner hub spin by itself inside the big clutch basket? so stopping the gears wouldnt do much would it? i got that primary gear nut torqued with a home made tool.... but the clutch nut?? I just put my chain on my sprocket and bind it up like it was goin to to bust your case. Should stop that inner hub from turning. There may be a better way .. but this worked fine for me. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 30, 2007 Report Share Posted January 30, 2007 i like the fiber and steel thing to hold the inner and basket and just put a penny in the gears.. but like i said above i got the tool so i didnt have to bother with it... i think i paid like 23 dollars or something like that for it... Quote Link to comment Share on other sites More sharing options...
sheefreak Posted January 30, 2007 Report Share Posted January 30, 2007 I just put my chain on my sprocket and bind it up like it was goin to to bust your case. Should stop that inner hub from turning. There may be a better way .. but this worked fine for me. I wouldn't go this route either. It is a lot of undue stress on a lot of parts(tranny gears, shafts, cases...). Quote Link to comment Share on other sites More sharing options...
