3 Posted January 29, 2007 Report Share Posted January 29, 2007 Hi guys, my question is, can i use a set of front Elka that were on a YFZ450 to put them on my Banshee?? I am going to run into the same problems as using the 450 stock shocks or it will bolt on perfect?? THank you Quote Link to comment Share on other sites More sharing options...
3 Posted January 29, 2007 Author Report Share Posted January 29, 2007 I forgot to mentioned, shocks are w/o res or piggy back and 16.5 in length and will go on +2+1 a arms. Quote Link to comment Share on other sites More sharing options...
Ruko Posted January 29, 2007 Report Share Posted January 29, 2007 Hi guys, my question is, can i use a set of front Elka that were on a YFZ450 to put them on my Banshee?? I am going to run into the same problems as using the 450 stock shocks or it will bolt on perfect??THank you They should bolt right up without any mods to the mounts like you need to do with the stock 450 shocks. Unless you get the bottom mounts moved on the lower a-arm you will still have the problem of them being too long though. Quote Link to comment Share on other sites More sharing options...
3 Posted January 29, 2007 Author Report Share Posted January 29, 2007 Did you say that the 16.5 shock is to long for a Banshee front end?? Quote Link to comment Share on other sites More sharing options...
