Mullet Man Posted January 27, 2007 Report Share Posted January 27, 2007 Just run outframes :yelrotflmao: lmao now that would be a site Quote Link to comment Share on other sites More sharing options...
JET 99 Posted January 27, 2007 Report Share Posted January 27, 2007 post some pics or a vid............. if you try to tackle it.. i would like to see some of the mods you would end up doing. coolant capacity? exhaust? front sprocket-chain-rear drive sprocket alignment? if you try to center the shee motor in the frame i bet you find your rear sprocket is outside your swingarm width.. (motor offset?) exhaust can you tig weld? cause you need to fab up some one of a kind shit that flows correctly.. extra weight load on front forks (heavier motor) frame modification. motor mount tabs,cyl head clearence,type of air filter setup,throttle cable length(might be way off).... it would be wicked but like alky said ------------------------ good fabricator skills required!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
felcon edition banshee Posted January 28, 2007 Report Share Posted January 28, 2007 well the banshee moter was first on a yamaha street bike before it became a quad so alot of fabrication should just abot do it Quote Link to comment Share on other sites More sharing options...
gipperz Posted January 28, 2007 Report Share Posted January 28, 2007 well the banshee moter was first on a yamaha street bike before it became a quad so alot of fabrication should just abot do it I had a yamaha rd250 (1972 ). I made that into a dirt bike and it was scary fast. Same motor as the banshee but it was air cooled. I still have the frame sitting at my Dads, motor is long gone but sure brings back memories. Anything can be done but how much time and money are you willing to put into it? Quote Link to comment Share on other sites More sharing options...
doorslammer Posted April 10, 2007 Report Share Posted April 10, 2007 yer im a bit late but... put the cr500 motor in it and than have duel exhausts. that would look cool Quote Link to comment Share on other sites More sharing options...
