ASR Arms
yamaha04
hey guys i just bought a set of new ASR Arms +2+1 its says they are for stock lenght shocks? is this right also would se set of yfz shocks work good. the yfzs have a longer a arms so it should be about the same i think.? i need a shock setup but dont want to break the bank and im not to sure on the stock lenght thing that asr says. does anyone have these arms with stock shocks if so did your ride hight change?
I think the stock shocks will be a little soft, but the yfz shocks are compression adjustable so I don't see why they won't work.
yeah i was definatly not going to use the stockers but it says i need stock lengh . i though that was kinda weird for a +2+1 A arms. oh well i think the yfz shock will be the cats ass from what if been reading on here from poeple that have +2 arms anyone fell free to give some more info
the position of the lower shock mount has nothing to do with +2+1 on your a arms..
the length of the shock versus were your shock mount is located on the lower arm detrmines what you should put on your arms. hell call asr with the length of the shock you want to run see what the say.
if they want your repeat business and a good reputation they should give you an answer....
thanks jet they must have moved the bottom mount up on the arms so that stock lenght would work. i think the yfz should work. they definatly wont be stiff because of the extra leverage of the +2 arms and lots of people are running them with stock arms
Yeah like he said they are for stock length shocks. You are going to love those a-arms as long as your shocks are stiff enough to eliminate body roll. My gf has +3+1 asr arms on her blaster. The welds are really good. which asr arms did you get? The thinner or thicker ones?
um i got the .120 wall ones i dont do much jumping but i may hit acouple once in awhile. they are the ASR sport star +2+1. i was going to get the sport star plus but i really dont need all that adjustment
how do they not fit through the a-arms? the arms arent wide enough? you would think that you would be able to use them b/c if u can use them on the stock a arms, as long as u dont get a LT kit then you wouldnt have a problem?
yeah thats what i was think i was just wondering if the setup would work good with the yfz shocks
Ok.. let me clarify.. Before I bought my setup & doing the research there was members on here complaining bout the a arms they bought that would not work with these yfz shocks {shocks/springs are wider.} maybe those member's will read up on this one and chime in??
That's how i found out that Sandragon Mot....... & Quicksand would work for me.
Though yfz's are longer than stocks, might not be long enought for an LT setup. The shock conversion thread has the measurements eye to eye. Compare that to an LT shock eye to eye to find out if they'll reach.
