smokin 2 stroke Posted January 23, 2007 Report Share Posted January 23, 2007 OK SO ONE OF MY FRIENDS HAD TO SCIENCE FAIR PROJECT AND HE DID HIS ON ACID TONE AS AN ADDITIVE HE TESTED IT ON HIS MOWER. HE SAID THE GAS LASTED FOR AN EXTRA HOUR AND RAN ALOT BETTER OR SOMETHING LIKE THAT. SO MY QUESTION IS CAN IT BE USED WITH THE SHEE. Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted January 23, 2007 Author Report Share Posted January 23, 2007 (edited) OK SO I DID SOME RESEARCH IN IT HERES A LINK SCROLL SOWN SOME http://peswiki.com/index.php/Directory:Ace...-Stroke_Reports Edited January 23, 2007 by smokin 2 stroke Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted January 23, 2007 Report Share Posted January 23, 2007 It's acetone. And it can be added to fuel, it actually helps to break up deposits in fuel injection systems, it's used in basically all thos fuel injection cleaners at Pep Boys or Vato Zone. I don't know how much you actually mix, I've heard 1 ounce to 1 gallon, but I'm not 100% on that. If your planning on using it on a Banshee, I wouldn't it only takes an hour to take off the carbs and actually clean them, and that will work better. I wouldn't risk harming the engine when there is a simple proven way to clean the carbs. Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted January 23, 2007 Author Report Share Posted January 23, 2007 OK GO TO GOOGLE AND AND TYPE IN ACETONE AS FUEL ADDITIVE IT IMPROVES GAS MILAGE UP TO 12 PERCENR AND IT 1 ONCE FOR EVERY 10 GALLONS. IT MAKES IT BURN LONGER Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted January 23, 2007 Report Share Posted January 23, 2007 OK GO TO GOOGLE AND AND TYPE IN ACETONE AS FUEL ADDITIVE IT IMPROVES GAS MILAGE UP TO 12 PERCENR AND IT 1 ONCE FOR EVERY 10 GALLONS. IT MAKES IT BURN LONGER I think you answered your own question Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted January 23, 2007 Author Report Share Posted January 23, 2007 YES I MIGHT HAVE...BUT I WAS WONDERING WHAT U GUYS THOUGHT OF IT. IM GOING TO TEST IT ON MY MOWERS THIS WEEKEND Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted January 23, 2007 Report Share Posted January 23, 2007 wow dude we get your point. whats with the CAPS Quote Link to comment Share on other sites More sharing options...
halfrack Posted January 23, 2007 Report Share Posted January 23, 2007 Not to be rude, but if you cant even spell ACETONE I dont think you should use it. Especially if you give us a link that I assume you have read and has the correct spelling . Quote Link to comment Share on other sites More sharing options...
okbeast Posted January 23, 2007 Report Share Posted January 23, 2007 Not sure what all the gas would come in contact but acetone is not good for seals and what not, they'll eventually break down, and alot sooner. Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted January 23, 2007 Report Share Posted January 23, 2007 dude they did that on mythbusters and proved it to be a myth about it improving gas mileage. Quote Link to comment Share on other sites More sharing options...
Washburn Posted January 23, 2007 Report Share Posted January 23, 2007 I wouldnt put in any additive that hasent been proven to work in 2 stroke atv/bike engines. It could end up binding all sorts of shit up. Never have never will. If you dont see it in pro shops and mechanics either dont know if it will work or they tell you they wouldnt use it in their bikes that pretty much sums it up. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted January 23, 2007 Report Share Posted January 23, 2007 Will that gas still allow the engine to produce good power? Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted January 23, 2007 Report Share Posted January 23, 2007 Will that gas still allow the engine to produce good power? We used to put acetone in our gas back in the early 90's when we had leaded fuels. Nowadays we just run 92 octane unleaded. I cant remember why we did it, but I can ask dyno dave next time I see him. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 23, 2007 Report Share Posted January 23, 2007 I wouldnt put it in my gas. Acetone is way more flamable and volital than gasoline. If you add it to your fuel your are lowing the octane number. To low then you start detonating. Try an experiment. Put some plastic parts in acetone. Watch them melt and think if that would be cool to do to the plastic and rubber parts in your carburetor, fuel tank, and fuel tank valve. Do you really think that all the big name oil companies paid there Chemical Engineer's big money, and come to find out they for got to add the acetone? Quote Link to comment Share on other sites More sharing options...
csrmel Posted January 23, 2007 Report Share Posted January 23, 2007 mythbusters tried acetone in some fuel economy test and proved it to be bogus. jbooker82, acetone only attacks certain types of plastics, not all of them. i am reasonable sure the banshee gas tank and the rest of the plastic and rubber parts in the fuel system would be OK. but hey you still wont find me running acetone in my fuel. Quote Link to comment Share on other sites More sharing options...
