bansheecaptain Posted January 19, 2007 Report Share Posted January 19, 2007 i was woundering if anyone has tried useing CPI on a single carb set up , i run open trails most of the time and a couple dune trips so i ride top throttle most of the time , i have FMF gold series right now , any info would be great thank you , just woundering how they do fast and slow pace with the single carb ,,thanx Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 19, 2007 Report Share Posted January 19, 2007 I've never tried it like that, but I would guess they probably wouldn't be the best with a single carb... CPI's are more of a high midrange and to end pipe, so trying to run them with a low-end setup probably wouldn't be the best. Yeah, it will probably work, but not how you would really expect them to work... - Jared Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted January 20, 2007 Report Share Posted January 20, 2007 (edited) i was woundering if anyone has tried useing CPI on a single carb set up , i run open trails most of the time and a couple dune trips so i ride top throttle most of the time , i have FMF gold series right now , any info would be great thank you , just woundering how they do fast and slow pace with the single carb ,,thanx Thats a top end pipe with a bottom end carb setup. Typically you wont have enough exhaust gas to use the pipes to its potential, because you would be bottle necking the intake because of the very small carb inlet size. Banshees dont really have a way of making the best of both worlds with a bunch of bottom end parts, and some top end parts together. You gotta more look at what you want, say maybe really good midrange for your setup, and gear all your components towards that. My only engine mods are a coolhead at about 170 psi compression, a 34mm pwk, stiffer clutch springs, and 2 into 1 intake with a dynoport 2 into 1 pipe. My bike is actually pretty fast and its a blast to ride. I do well in the holes, and pretty good drag racing up the hills. The flats are a bit of a letdown, once I get into sixth gear I dont have enough top end to really carry my last gear. I am geared at 13/45 with 22" sand tires. This is me climbing out a hole. Snopczynski in a really steep hole Ok, so here we are racing up boxcar in Coos Bay, OR. The guy in front has Paul Turner Torque pipes, 2 into 1 carb setup, and a 4mm long rod stroker motor ( 406cc $30k banshee). Guy in Second has CPI's with dual carbs and a ported 350 ($15k banshee). Im on the blue one in third with only the engine mods listed above. Not too shabby for just a stock motor with a few bolt on parts ehh? Drag Race at Boxcar Edited January 20, 2007 by Snopczynski Quote Link to comment Share on other sites More sharing options...
