sykoman Posted January 17, 2007 Report Share Posted January 17, 2007 (edited) what does it take to put a rz 350 trans in a banshee? can u just drop the gear clusters in a banshee case....or do u have to mod anything??? Edited January 17, 2007 by sykoman Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted January 17, 2007 Report Share Posted January 17, 2007 Just a drop in as far as I know, the bottom cases are basically identical. Quote Link to comment Share on other sites More sharing options...
Yaxy Posted January 17, 2007 Report Share Posted January 17, 2007 Yes, The cluster drops right in. My current RZ has banshee cases. Chris Quote Link to comment Share on other sites More sharing options...
Yaxy Posted January 17, 2007 Report Share Posted January 17, 2007 Yes, The cluster drops right in. My current RZ has banshee cases. By the way, you are aware that the RZ gearing is taller than the shees? Also, most people like the shee gearing but use the RZ shift forks. Shifting is 100% better. Chris Quote Link to comment Share on other sites More sharing options...
djackbanshee Posted January 17, 2007 Report Share Posted January 17, 2007 Yes, The cluster drops right in. My current RZ has banshee cases. By the way, you are aware that the RZ gearing is taller than the shees? Also, most people like the shee gearing but use the RZ shift forks. Shifting is 100% better. Chris What's different between the rz and banshee forks ? why is it better ? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 17, 2007 Report Share Posted January 17, 2007 the shift forks shouldnt make that much of a differance if any for that matter... one of the main down falls of the banshee shifting is the star and shift shaft... not the forks... most shity thing with the forks is they are prone to bending if you shift clutcless... but other then that i want to say they are identical? but im not for sure... Quote Link to comment Share on other sites More sharing options...
sykoman Posted January 18, 2007 Author Report Share Posted January 18, 2007 I was just looking up the shift forks for both bike and the forks are identical but looks like the RZ uses pins over the forks that ride in the smaller shift drum.... in the pic the drum also looks longer and it has some extra pieces on the end.... are the drums and shift forks interchangeable.... I keep bending #2 shift forks which was why I was thinking I might have to change my cluster....so I was thinkin bout using th RZ for the taller gear....anyone done this? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 18, 2007 Report Share Posted January 18, 2007 I was just looking up the shift forks for both bike and the forks are identical but looks like the RZ uses pins over the forks that ride in the smaller shift drum.... in the pic the drum also looks longer and it has some extra pieces on the end.... are the drums and shift forks interchangeable.... I keep bending #2 shift forks which was why I was thinking I might have to change my cluster....so I was thinkin bout using th RZ for the taller gear....anyone done this? I would check something else...if you keep bending it. What are your mods? Is it possible an override would suit you better? Is it possible something is bent, misaligned or out of adjustment as is right now? Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted January 18, 2007 Report Share Posted January 18, 2007 RZ gears are also narrower, Ive seen banshee trannys with the RZ 6th gear, that would be sweet. If you do a search I posted the RZ and the Banshee tranny ratios side by side a while back ago. :beer: Quote Link to comment Share on other sites More sharing options...
sykoman Posted January 18, 2007 Author Report Share Posted January 18, 2007 very possible on the adjustment bein out of line...I'm gonna look real hard when I get a chance...but how would they get out out of alignment... I had a mecanic of 18 years replace it last and he said it looked great.... I'm not racing it just playin in the dirt n trails..... Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 18, 2007 Report Share Posted January 18, 2007 I run RZ Transmissions in all the banshees I own. Its pretty much drop-in. I would definitely suggest it if you have the time and can find a good rz transmission to put in there. The shift forks are a little bit beefier and hold up a little better to abuse as well. - Jared Quote Link to comment Share on other sites More sharing options...
sykoman Posted January 18, 2007 Author Report Share Posted January 18, 2007 so would i need the gear clusters and shift forks and pins ... or do i need to change the drum as well? Quote Link to comment Share on other sites More sharing options...
Yaxy Posted January 18, 2007 Report Share Posted January 18, 2007 I still think the shift forks and drum or just the forks are why the RZ shifts so well. I replaced the shift star with a new shee one and that made no difference in how it shifts. Chris Quote Link to comment Share on other sites More sharing options...
Coester Posted March 26, 2020 Report Share Posted March 26, 2020 I can see most of the posts in this thread are VERY old, but most everything posted on here is incorrect. Hopefully everyone figured out what was true and have a better understanding of the RZ and Banshee transmissions, their interchangeability and reality’s of running the RZ vs Banshee tranny. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted March 26, 2020 Report Share Posted March 26, 2020 I can see most of the posts in this thread are VERY old, but most everything posted on here is incorrect. Hopefully everyone figured out what was true and have a better understanding of the RZ and Banshee transmissions, their interchangeability and reality’s of running the RZ vs Banshee tranny.Go ahead, teach us.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
