ehenn34 Posted January 16, 2007 Report Share Posted January 16, 2007 just wonderin what has to be done to clean ur carbs and what i should look for as far as problems.. thanks Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted January 16, 2007 Report Share Posted January 16, 2007 You should start with one at a time that way you don't mix the parts up between carbs. Plus if you forget where something goes you will have a duplicate carb for reference. Clean out all the jets, the mains, and the pilots, and make sure they are not plugged up. Clean the slides, as well as the floats and bowls. I usually take compressed air and blow all of the tubes that are drilled through the carbs just in case there is any dirt or sand in them. Plus when you put them back on the bike make sure you put the crossover tube back on, and then sync them together with a carb sync tool............ :thumbsup: Quote Link to comment Share on other sites More sharing options...
ehenn34 Posted January 16, 2007 Author Report Share Posted January 16, 2007 You should start with one at a time that way you don't mix the parts up between carbs. Plus if you forget where something goes you will have a duplicate carb for reference. Clean out all the jets, the mains, and the pilots, and make sure they are not plugged up. Clean the slides, as well as the floats and bowls. I usually take compressed air and blow all of the tubes that are drilled through the carbs just in case there is any dirt or sand in them. Plus when you put them back on the bike make sure you put the crossover tube back on, and then sync them together with a carb sync tool............ :thumbsup: sounds good,, thanks Quote Link to comment Share on other sites More sharing options...
Washburn Posted January 16, 2007 Report Share Posted January 16, 2007 They also sell a carb cleaner in a spray can or a big gallon bucket with a strainer. That stuff comes in super handy just make sure not to spray any rubber pieces "floats" just jets and all inside of your carbs. Probably RMATV has some or your local shop. Quote Link to comment Share on other sites More sharing options...
