ALTVATER Posted January 16, 2007 Report Share Posted January 16, 2007 i just got a carb sync and i am not exactly for sure how u r supposed to set up ur carbs to use it. if anyone has any spects or anything helpful post it on here. from what i am getting from the directions ur supposed to set them up where everything sounds good then put the sync on there and tune them the same. if that is wrong or there is a different way to do this please tell me. thanks Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 16, 2007 Report Share Posted January 16, 2007 i just got a carb sync and i am not exactly for sure how u r supposed to set up ur carbs to use it. if anyone has any spects or anything helpful post it on here. from what i am getting from the directions ur supposed to set them up where everything sounds good then put the sync on there and tune them the same. if that is wrong or there is a different way to do this please tell me. thanks You got a pic or a link as to what type of tool you are talking about?? Quote Link to comment Share on other sites More sharing options...
Washburn Posted January 16, 2007 Report Share Posted January 16, 2007 I got the one from Jeff and havent been able to get to my bike to try it out yet. I have an idea on how to use it but Ive never used or even seen one before and some tips and instructions other than the ones that came in the box would be appricated. Oh in the instructions it says something about the throttle plate I figure they are talking about the slides? Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted January 16, 2007 Report Share Posted January 16, 2007 Well, if it's like this one... Then you'll get your carbs as close as you can to synced, keep the air filters off the carbs and fire it up and let it idle. Press the sync tool up to the carb inlet and see what you got. The carb tool measures the velocity of air moving through it. Take it off the first carb and press it to the second carb. If the velocity looks the same, then hit and hold the throttle at 1/4 throttle...see where it's at and then put it back on the other carb....if the number is the same then hold it to roughly half throttle...check both carb's velocity and adjust the slides/air screws accordingly. That's how I did mine and it worked great...I didn't realize my carbs were out of sync until I used it, great tool to have Hope that made some sense, lol, I'm not the best when it comes to explaining things...once you stick the carb tool up to the carb and see the little gauge move with the throttle/air you'll figure out exactly how to use it...didn't take long to figure out :biggrin: Quote Link to comment Share on other sites More sharing options...
wood Posted January 16, 2007 Report Share Posted January 16, 2007 took the tors off put on twist grip with idle screws,if both carbs are set up the same going off of the idle screws would that sync them pretty close,or is there alot more to syncing carbs. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted January 16, 2007 Report Share Posted January 16, 2007 Yeah, there's a little more to it....gotta make sure both your slides are opening at the same time...your eye will get it really close, but this carb sync tool will make sure it's perfect. Quote Link to comment Share on other sites More sharing options...
wood Posted January 16, 2007 Report Share Posted January 16, 2007 thanks. Quote Link to comment Share on other sites More sharing options...
ALTVATER Posted January 16, 2007 Author Report Share Posted January 16, 2007 Yeah i got mine from jeff it is like the one in the picture above Quote Link to comment Share on other sites More sharing options...
ALTVATER Posted January 16, 2007 Author Report Share Posted January 16, 2007 and thanks for the explanation they give some shitty directions in the box. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted January 16, 2007 Report Share Posted January 16, 2007 Well I got one from Jeff too. And its the same one thats in the picture and when I read the instructions they sounded pretty much like what was said above.................. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted January 16, 2007 Report Share Posted January 16, 2007 Altvator, give me a holler if you need help with it as i tried to call you the other day but dont have the right #. Bigboy pretty much had it correct. Set the idle screws so the tool reads the same , then rev it up and hold it about 1000 rpm higher steady and set the pull with the carb top adjustes. Torque em down, double check and your done. Real easy. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 16, 2007 Report Share Posted January 16, 2007 I set mine at idle, then again at 3/8 to 1/2 throttle. Once the slack is taken out of the cable (off idle) you should only have to measure it once, it shouldn't change once the slides are no longer touching the idle screws... It sure is a handy little tool to have.. Quote Link to comment Share on other sites More sharing options...
