Plug Wires
Hey guys, can the sparkplug wires on the stock coil be replaced?
you know iv never heard of anyone replacing just the wires o stockers.. usally the whole thing... i took a look at mine and they are sloted and locked in place so im sure you can get them out to replace.. not sure if they are soldered in or not i havent opend one open before
If you get Nology Hot Wirze they come with a splice. You cut the original wire off the coil leaving about 1 in stick out of the coil. You thread on this sleeve on to the coil wire(like those coax tv cable ends) then you do the same for the hot wire. I would just get the Nology coild and then you use wires that have the real plug boot on each end. No splicing.
