rz 350 cases
lunatic
  • 3 weeks later...
You can use RZ cylinders on banshee cases but you cannot use shee cylinders on RZ cases. The components from the RZ drop righ into the bsnshee cases, no problem.
Chris
The RZ cases and the Banshee cases are the same thing.Both will interchange.
I agree with you guys in theory that there should be absolutely no difference, Just repeating what I read in the past which did not make a lot of sense to begin with. It is also strange that if you price new cases the RZ ones run $700 + and the shee at $400 +, this also makes no sense.
Chris
