highroller355 Posted January 10, 2007 Report Share Posted January 10, 2007 if i run big hoses from carb to airbox with pro flow set up with the uni filter and no lid will this be able to breath enough i wnt to keep air box worried about the k and n filter sucking up water or falling off Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 10, 2007 Report Share Posted January 10, 2007 What do you have for intake manifolds? I ran an air box with my Keihin PJ34mm carbs and it was a pain in the butt. I used those UPP intake carb boots and the boots that go from the carbs to the air box. It was a pain to get to the carbs to jet them. The air box gets wedged realy tight because the keihin carbs were longer and took up more room. Quote Link to comment Share on other sites More sharing options...
highroller355 Posted January 10, 2007 Author Report Share Posted January 10, 2007 What do you have for intake manifolds? I ran an air box with my Keihin PJ34mm carbs and it was a pain in the butt. I used those UPP intake carb boots and the boots that go from the carbs to the air box. It was a pain to get to the carbs to jet them. The air box gets wedged realy tight because the keihin carbs were longer and took up more room. trinity stage 4 bilet intake v force 3 reeds and reed spacer Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 10, 2007 Report Share Posted January 10, 2007 With those bigger/longer carbs, Vforce AND the reed spacer, I'd have to say that's gonna be one tight ass fit. You might want to think about a custom aluminum airbox, if you've got the coin... Quote Link to comment Share on other sites More sharing options...
CMAC Posted January 10, 2007 Report Share Posted January 10, 2007 With those bigger/longer carbs, Vforce AND the reed spacer, I'd have to say that's gonna be one tight ass fit.You might want to think about a custom aluminum airbox, if you've got the coin... Im going to be going with the same set up eventually, do you know who makes an air box like that? Quote Link to comment Share on other sites More sharing options...
highroller355 Posted January 20, 2007 Author Report Share Posted January 20, 2007 (edited) got it done very easy look neat to to Edited January 20, 2007 by highroller355 Quote Link to comment Share on other sites More sharing options...
blaster668 Posted January 20, 2007 Report Share Posted January 20, 2007 I believe CFM has new aluminum airboxes for like $89 buy it now on Ebay. In the auction they give prices for the larger boots and such as well. It uses two pod filters in the box. Quote Link to comment Share on other sites More sharing options...
tbd Posted January 22, 2007 Report Share Posted January 22, 2007 highroller: how is the box held in?..... i'm in the process of doing mine Quote Link to comment Share on other sites More sharing options...
highroller355 Posted January 22, 2007 Author Report Share Posted January 22, 2007 highroller: how is the box held in?..... i'm in the process of doing mine i made up 2 little brackets i will get better pic for you tomorrow if you want set it back a coupl inches works great rode hard today didnt move at all and alot cheaper than any other air box and works just as good Quote Link to comment Share on other sites More sharing options...
