j arm spindles
sand rocket
anyone know if a 89 j arm banshee has the same spindal as a a arm banshee. I purchaced some brake calipers and cant finger out how to mount them. Im almost positive that the spindals are diff. Anyone know for sure?
the older j arm style shees used a different caliper than the newer a arm type .
yes you can use a-arm spindles on j-arms the ball-joints are all the same. if you need a set of j-arm brakes let me know, i have 2 good sets in my garage. or if you need a-arm spindles let me know i think i have a good set out there too. if you want the j-arm brakes i would be willing to work out some kind of trade.
and yes the spindles are different. the caliper mounting brackets are closer together on the j-arm set. this is one thing i do know for sure.
Edited by nunyabinness
Were are you from? What kind of a trade we looking for the j arm calipers?
i think thats wrong , i had a 90 j arm banshee and changed the frame to a a arm and used the same brakes and spindles , ,
i think that its the 87 brakes are different ,, maybe 88 also , but i know 90 j arm spindles are the same as a arms
i don't know what year they changed the brakes out on the banshee. but there are 2 different brake sets. one is the newer style and then there is the older style that looks like this:
if the brakes look like the ones above then no the spindles are not exactly the same. i will post a pic of the 2 to show you the difference. they ARE interchangeable but the brakes can only be used with the correct spindles because they are not interchangeable. like i said i don't know what year they changed but i know there is a difference. here is the pic to prove my point. look at the mounting brackets for the brakes, on the j-arm banshee spindles they are closer. that is the only difference.
