snedden9485 Posted January 8, 2007 Report Share Posted January 8, 2007 hey guys, what are the DG pipes like in terms of performance. The full exhaust system will most likely be the only real major modification i will be doing at this stage. Just after a pipe that will sound good and give abit more scoot. cheers chris Quote Link to comment Share on other sites More sharing options...
miner Posted January 8, 2007 Report Share Posted January 8, 2007 never rode one with that set up but im sure you will be happy with the performance and sound compared to the stockers :thumbsup: Quote Link to comment Share on other sites More sharing options...
woodro77 Posted January 8, 2007 Report Share Posted January 8, 2007 i had a set of dg pipes on my shee when i bought it , not as good as toomy's or fmf's but they are tons better than stock pipes Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 8, 2007 Report Share Posted January 8, 2007 If you can find DG pipes for less than 200 bucks in pristine shape, then I'd say go for it. Otherwise, for 300 or less, you can find T5 pipes or FMFs, which...most will tell you will outperform and sound better than DGs. ANYTHING is better than stock, but if pipes are all you're gonna get...might as well get ones that perform a little better on a stock motor...just my .02. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted January 8, 2007 Report Share Posted January 8, 2007 DG pipes came on the banshee I bought 4 years ago, it had nice smooth power throughout the powerband. They're definitely not the best, but they did the job back when I couldn't afford new pipes. I upgraded to T5's and could definitely see a difference between the two, but nothing dramatic. T5's are a better pipe if you can afford to find a set, but the DG's will do well if you're on a budget Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted January 9, 2007 Report Share Posted January 9, 2007 DG pipes came on the banshee I bought 4 years ago, it had nice smooth power throughout the powerband. They're definitely not the best, but they did the job back when I couldn't afford new pipes. I upgraded to T5's and could definitely see a difference between the two, but nothing dramatic. T5's are a better pipe if you can afford to find a set, but the DG's will do well if you're on a budget Work! My first set of aftermarket pipes was DG. I changed them for DMC 916's, I see a diffence but nothing dramatic like Bigboy said. If you dont have 500$ spend for T5 or others and you have a good deal for DG, take it. Quote Link to comment Share on other sites More sharing options...
