got ported engine need advice please
twojztt
03 banshee with stage 5 porting with 34 mm kiehn carbs,vforce reeds,19cc domes,pro desighn coolhead,wisesco pistons,vitos fat bastard pip degrees + 5 timing advance,k n filter 150 psi kicking pressure.Shouldnt the psi be higher the bike feels sluggish and bogs in 1 st 2nd.Top end does not bod or pop but does not feel much faster than unported should i get 18cc domes i am not scared of race fuel.Also it does not idle no matter how much you adjust the idle adjusters.
Edited by twojztt
150 psi would not be uncommon with that set up. You should be running race fuel though. Here where I run 34 pj's on a similar set up.
155 mains
CGM middle notch, C series needles will be the better choices.
55 pilots
60 slides.
155 mains
55 pilots
60 slides.
i am running race fuel,but would like more compression,is there a need for 17cc domes or 18cc
if you want more compression then yea you need smaller domes... but with your mods 150 isnt bad... why exactly do you want more compression? the gains are minimal versue the money you spend on the gas... right now you can run 50/50 and be perfect and you wont see really any gains by going to stright race gas..
155 mains
55 pilots
60 slides.
if the bike does not pop or bog top end arent the main jets correct?
not necissarly, only way to check your jetting is pulling your plugs and reading them...
2 strokes arnt like 4 strokes you cant do your jetting by popping or backfireing...
plugs look chocolate brown,if i turn the air adjustment skrew they get fuel fouled and wet but can adjust and they are a chocolate brown.
Edited by twojztt
