socal_450rider Posted December 23, 2006 Report Share Posted December 23, 2006 is there any way to lighten the slide spring on the single 35mm carb Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 23, 2006 Report Share Posted December 23, 2006 Get a squeezeball for practice at work... Seriously, if you have an issue pulling a single throttle spring on a thumb...not sure what to tell you...if the carb is clean, etc., it should be a breeze to pull. Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted December 23, 2006 Report Share Posted December 23, 2006 you can cut some of the coils off and strech it back to the same lenght or call jeff at fast and he can get you some softer springs Quote Link to comment Share on other sites More sharing options...
socal_450rider Posted December 23, 2006 Author Report Share Posted December 23, 2006 the only time it bothers me is on long rides but someone told me to cut it a lil bit and lube it which ive never done so ill try that and see how it is Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted December 23, 2006 Report Share Posted December 23, 2006 Try an extended thumb throttle lever also. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 25, 2006 Report Share Posted December 25, 2006 Order a softer spring from Jeff at FAST. I have them in my dual 33mm carbs and they pull easier than the stock carb setup. I took my extened thub throttle lever off because I dont like how far you have to push it to get to WOT. Quote Link to comment Share on other sites More sharing options...
