uscgflorida Posted December 23, 2006 Report Share Posted December 23, 2006 Ok guys, this is my first banshee and my first 2 stroke. Bone stoke except a pro design foam filter and twist throttle with the tors removed. I upped the main jet to 220. Now all it does is bog BAD from about 1/2 to wot. I tried to put the chocke on the first nocth and it was worse. Am I too lean or too rich?? Too rich right?? It does start alot better now since I did the filter and removed the tors. It starts on the first kick. Please help Live in florida,sea leval, about 75 degres. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 23, 2006 Report Share Posted December 23, 2006 Did you properly and carefully sync the carbs? Turn the air screws all the way in. .5 turns out from seated, keep turning the air screws 1/2 turn out until it wakes back up. Allow 20 seconds between air screw adjustments for the bike to "react" from it. Get rid of that snorkel while you're at it... A few basic questions. 1. Carb slides in the wrong carb? that can cause this. 2. Choke tube back in place between the two carbs? 3. Carb bowls on the right carbs? Quote Link to comment Share on other sites More sharing options...
uscgflorida Posted December 23, 2006 Author Report Share Posted December 23, 2006 Did you properly and carefully sync the carbs?Turn the air screws all the way in. .5 turns out from seated, keep turning the air screws 1/2 turn out until it wakes back up. Allow 20 seconds between air screw adjustments for the bike to "react" from it. Get rid of that snorkel while you're at it... A few basic questions. 1. Carb slides in the wrong carb? that can cause this. 2. Choke tube back in place between the two carbs? 3. Carb bowls on the right carbs? Snorkel and the lid is gone. Carbs are synced, I did one carb at a time, Chock tube back in place. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 24, 2006 Report Share Posted December 24, 2006 Conventional wisdom would say 220 to 240 main with stock everything, filter and no airbox lid. If everything is up to snuff...lean out the main. Careful...and check the plugs along the way... Quote Link to comment Share on other sites More sharing options...
Jhughes7 Posted December 24, 2006 Report Share Posted December 24, 2006 If you dont mind, could you please Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted December 24, 2006 Report Share Posted December 24, 2006 If you dont mind, could you please In that case why dont you make yours smaller? huh? its a little on the tall side. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 24, 2006 Report Share Posted December 24, 2006 If you dont mind, could you please No offense...I'm gonna have to agree... Quote Link to comment Share on other sites More sharing options...
csrmel Posted December 25, 2006 Report Share Posted December 25, 2006 honestly i believe yamaha jets the stock banshee a hair rich right from the factory. so if you pulled the lid you would probably be spot on with 200's or 210's. but in reality that bike isnt going to bog with anything from 200 to 240. i doubt youre bogging is related to the mains. on my bike i can put anything from 280 to 350 in and it wont bog. id bet you did something wrong with you re assembled the carbs. perhaps the slides are in wrong. do a plug chop and post up the pics. Quote Link to comment Share on other sites More sharing options...
uscgflorida Posted December 25, 2006 Author Report Share Posted December 25, 2006 Ok shes back to life now. come to find out I was runng really lean. End resalt I went with a 260 main, one clip down from stock on the neddle, and 1 turn out on the air screws. She is runng better now than when i first got it. Plugs are a light brown coffey color. thank for all your help. Quote Link to comment Share on other sites More sharing options...
uscgflorida Posted December 25, 2006 Author Report Share Posted December 25, 2006 If you dont mind, could you please Changed the picture just for you man. Practice What you Preach, yours isnt that size either, allittle on the tall side. :beer: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 25, 2006 Report Share Posted December 25, 2006 Glad to hear...do a proper plug chop just to be sure your mains are dialed in!! Quote Link to comment Share on other sites More sharing options...
csrmel Posted December 25, 2006 Report Share Posted December 25, 2006 unless youve got an airleak, there isnt any way a stock banshee could go from 200's to 260's with just a filter and lid. hell t5's are 1 step away at 280. spary some ether or carb cleaner around the boots and carbs. Quote Link to comment Share on other sites More sharing options...
uscgflorida Posted December 25, 2006 Author Report Share Posted December 25, 2006 I checked for air leaks today, didnt find any. the reason i was checking way because when i start her up with the choke on the first notch I can hear air being sucked. (Yes the cross ove tube is in place) It only does it with the chocke on. other than that it is running really good. Quote Link to comment Share on other sites More sharing options...
