milo_32000 Posted December 22, 2006 Report Share Posted December 22, 2006 I want to install a temp gauge , I can`t find one that will make a neat installation, I do NOT want something that looks crappy ! Any ideas ? Thanks for the help ! Milo_32000 Quote Link to comment Share on other sites More sharing options...
bigdaddy69 Posted December 22, 2006 Report Share Posted December 22, 2006 I installed a temp guage recently, im still having problems with it though. Everything works ok I still have a small leak though....What I did was went to the lumber store and bought a 1/2 tee, found some 1/2 barbed fittings screwed that into the tee and spliced that into the hose coming from the head to the top of the radiator. Then I ran into another problem, the probe on my guage was going to be too long and restrict my flow. I then went on a search for a 1/2 fitting that was female one one side and male on the other....only thing i could find was a flare type fitting, so thats what i ended up with. I screwed the flare fitting into the tee then my guage probe into that and it gave me enough hight to not restrict my flow. The guage reads good, but its leaking around the flare fitting so i thik im goin to re do everything. for one because most everything I used was brass fittings which is really heavy, two it doesent look good, and three it leaks....do a search for temp guages, there are pictures around here somewhere Quote Link to comment Share on other sites More sharing options...
trueraiderfan Posted December 22, 2006 Report Share Posted December 22, 2006 These are the Shit http://www.warpdriveperformance.com/ And this guy is alcso my engine builder and he is also just 10 min from me. Quote Link to comment Share on other sites More sharing options...
band-one Posted December 22, 2006 Report Share Posted December 22, 2006 These are the Shit http://www.warpdriveperformance.com/ And this guy is alcso my engine builder and he is also just 10 min from me. This might be a dumb question....but how does it install? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 22, 2006 Report Share Posted December 22, 2006 I run an ESR 250 Temp gauge on my raptor. It is a quality unit. The Fitting is billit aluminum, and the gauge is liquid filled to vibrations wont destroy the gauge ESR 250 LINK On my banshee I just used a brass t fitting. Two stubs of pipe to slice in line with the upper radiator hose, a real short stub and a Female to Female adaptor. You cant see it cuase it is tucked up by the coil. Quote Link to comment Share on other sites More sharing options...
wesw Posted December 22, 2006 Report Share Posted December 22, 2006 This might be a dumb question....but how does it install? the big line that goes to the rad under teh shroud with the 2 holes you mount it there. works nice but you cant read it very well while riding. Quote Link to comment Share on other sites More sharing options...
uscgflorida Posted December 22, 2006 Report Share Posted December 22, 2006 This might be a dumb question....but how does it install? Here is a web site with some info. http://www.bluetraxx.com/review_tempgauge.htm Quote Link to comment Share on other sites More sharing options...
