mjr3 Posted December 17, 2006 Report Share Posted December 17, 2006 was curious to see what tire pressure people are runing with stock a arms n dual rates and +2 +1 forward a arms and dual rate shocks both used for heavy trails and moto x ..thanks Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted December 17, 2006 Report Share Posted December 17, 2006 look on the side of the tire. if you are running an 18" mx tire you should run 5psi. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted December 17, 2006 Report Share Posted December 17, 2006 look on the side of the tire. if you are running an 18" mx tire you should run 5psi. Way more than that for a mx tire. At least 7 lbs. http://www.itptires.com/tirereference.html Those are ITPs suggested pressure. And now that Ive been runnug mine at 7.5 lbs, I do notice a difference. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted December 17, 2006 Report Share Posted December 17, 2006 damn, I though I was supposed to run around 5psi Quote Link to comment Share on other sites More sharing options...
2005SEBANSHEE Posted December 17, 2006 Report Share Posted December 17, 2006 I run 23" HD's up front w. 5lbs. 4.5 in the rear. I've spent alot of time figuring out what works for my riding style, and weight Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted December 18, 2006 Report Share Posted December 18, 2006 Way more than that for a mx tire. At least 7 lbs. http://www.itptires.com/tirereference.html Those are ITPs suggested pressure. And now that Ive been runnug mine at 7.5 lbs, I do notice a difference. its like 10 to 15 psi to seat the bead. i run my mxr6's at 5 to 5 1/2 psi and it gives them a nice flat profile. Quote Link to comment Share on other sites More sharing options...
4strokessuck Posted December 18, 2006 Report Share Posted December 18, 2006 I give it the old "push down on the tire with your hand" technique on the front tires. Too hard and you feel every rock, rut, and stump on the trail. The rear tires, I eye up the tread so it's level for that even grip :thumbsup: Quote Link to comment Share on other sites More sharing options...
Washburn Posted December 19, 2006 Report Share Posted December 19, 2006 I give it the old "push down on the tire with your hand" technique on the front tires. Too hard and you feel every rock, rut, and stump on the trail. The rear tires, I eye up the tread so it's level for that even grip :thumbsup: yeah, I do the same but I still keep a pressure reading. A good gauge is like 5 bucks top of the line is like 12 bucks. Its usually 5-6 psi front and rear. I will have to see what I like when I get my Razr 2s. Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted December 19, 2006 Report Share Posted December 19, 2006 i only put my kendas up to 10psi to do doughnuts and slid the corners on the road befor i got my new rims and tires. but now i run 5psi in the mxr6's. Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted December 21, 2006 Report Share Posted December 21, 2006 On my razr mx tires i run 5 in the back but on the fronts i run 7-8. If i run 4-5 in the fronts i bend the shit out of the rims on big jumps. Fist few days i had them i was jumping with 5psi in the fronts and bent the lip on both my front rims i wasnt happy to say the least. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted December 22, 2006 Report Share Posted December 22, 2006 On my razr mx tires i run 5 in the back but on the fronts i run 7-8. If i run 4-5 in the fronts i bend the shit out of the rims on big jumps. Fist few days i had them i was jumping with 5psi in the fronts and bent the lip on both my front rims i wasnt happy to say the least. Yep, thats why. I've bent a rear rim before from having too little pressure (I always have kept the fronts high). If your running mx tires on a track, you aren't worried about the ride anyways, you want performance. Ask anybody that races mx what pressure they run. Its going to be closer to 10. Quote Link to comment Share on other sites More sharing options...
