dajogejr Posted December 18, 2006 Report Share Posted December 18, 2006 I think you mean a flywheel puller...and make sure you get the right one, that threads into the flywheel. A jaw type will permanently damage the flywheel. I'd get this thing torn down, checked out and go from there. I'd hate to see you start buying go fast parts when you might need a crank, bearings, etc., critical components. There are quite a few cheap bolt ons that will give you a noticeable bump in power. Timing plate is cheap, 35 plus shipping, shaved flywheel is nice to...less than 60 or so. However, the real power is in porting. The engine is apart now, so...the project/bike may not run a bit longer if funds are tight, but....if you save a few beans and get the porting done, it will be well worth the wait IMO. Any builder will tell you you're better off waiting until you bike is ready for a fresh top end to port the motor (Rather than tear down a perfectly good running bike...) Now is that time!!! Quote Link to comment Share on other sites More sharing options...
CHAWAWA Posted December 18, 2006 Author Report Share Posted December 18, 2006 yes a fly wheel puller is what I ment thanks I will see where I am at. I don't want to port the jugs cause I don't want to deal with the jetting that much. The temp changes so much around here and I ride in difrent locations and altitudes all the time and just to much to deal with. Was looking for other mods thanks for the good advice. Quote Link to comment Share on other sites More sharing options...
CHAWAWA Posted December 19, 2006 Author Report Share Posted December 19, 2006 fly wheel puller is on the way should have it dissesembled soon Quote Link to comment Share on other sites More sharing options...
CHAWAWA Posted December 24, 2006 Author Report Share Posted December 24, 2006 WELL SPLIT THE CASE AND IT SEEMS LIKE THE BARRINGS ARE BAD ON THE CRANK. THE ONE ON THE OUTSIDE ON THE CLUTCH SIDE IS LOOSE MY CONCERN IS THE BARRINGS IN THE CENTER THEY HAVE PLAY FROM SIDE TO SIDE. SO IM GUESSING I NEED A NEW CRANK. WELL LAST MOMENT BUT I NEED ONE ASAP I AM GIVEING MY 2 KIDS QUADS FOR X MAS AND I WOULD LIKE TO RIDE WITH THEM NEXT WEEKEND MY BUDGET IS UNDER $150 AND I LIVE IN TOLEDO OHIO. I AM WILLING TO DRIVE 2 HOURS AWAY. PLEASE HELP Quote Link to comment Share on other sites More sharing options...
DuneRookie Posted December 24, 2006 Report Share Posted December 24, 2006 Since you are in there go ahead and have your crank trued and welded... Quote Link to comment Share on other sites More sharing options...
