Question vforce V3 install
I am installing my v3's and need to know if I use all 4 gaskets supplied with kit? When i pulled off the stockers they only have 1 gasket on each reed cage between the cage and cylinder, the rubber o-ring on the carb boot seals to the cage. Do I use a gasket between the carb boot and the cage along with a gasket between the cage and cylinder the v3's? Thanks :headbang::headbang::headbang::headbang:
Edited by hotrodbanshee
