hotrodbanshee Posted December 12, 2006 Report Share Posted December 12, 2006 (edited) I am installing my v3's and need to know if I use all 4 gaskets supplied with kit? When i pulled off the stockers they only have 1 gasket on each reed cage between the cage and cylinder, the rubber o-ring on the carb boot seals to the cage. Do I use a gasket between the carb boot and the cage along with a gasket between the cage and cylinder the v3's? Thanks Edited December 12, 2006 by hotrodbanshee Quote Link to comment Share on other sites More sharing options...
Washburn Posted December 12, 2006 Report Share Posted December 12, 2006 Yup one on each side of the reeds. 2 reeds 4 gaskets. Quote Link to comment Share on other sites More sharing options...
Barrymaxx Posted December 12, 2006 Report Share Posted December 12, 2006 (edited) Yea, one between the boot and cage and one between the cage and cylinder. Edit: you beat me to it Edited December 12, 2006 by Barrymaxx Quote Link to comment Share on other sites More sharing options...
smwood79 Posted December 12, 2006 Report Share Posted December 12, 2006 oops, I only used 2? Seemed to run OK Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted December 12, 2006 Author Report Share Posted December 12, 2006 Thanks for the quick reply. Yup one on each side of the reeds. 2 reeds 4 gaskets. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 12, 2006 Report Share Posted December 12, 2006 My suggestion to use a thin skim coat of hit temp RTV, too.... both sides of both gaskets. THIN SKIM COAT.... Quote Link to comment Share on other sites More sharing options...
