2 into 1 question
Badley
For those who use or used A 2 INTO 1 38mm. Does it use less gas than the stock setup.In a couple of hours of riding I go thru 5 gallons of gas which is no big deal. I might try a friends 2 into 1 and just curious if it uses less gas. I gathes 2 26's actually I have 28's so 2 28's =56 as opposed to 1 38 So I would say yes anyone have an answer.Thanks
That's not the exact math...but I'm hoping another member can post up the math on that. You can't take the size of the carb and just double it....
don't want to steal you're thread but i was thinking about going that route also. just seems like it would be easier to jet and you probably won't burn your filters anymore(if you have inframes). idk how a single carb affects it performance wise though. is there any advantages as far as more power at certain RPMs over dual carbs? i'd like to know more about a single set-up too, if anyone has any experience with both. thanks in advance
Just get some cascade heat wraps. No more burnt filters. I would think that dual smaller carbs would be more responsive.
thanks for the advice, that make sense, i've seen old hot rods with triple deuces on them, always wondered why they didn't just run a big 4 barrell. must some benefits.
Well, back in the day large 4 barrel carbs were not available.
People use the deuces and stuff now for nostalgia sake, not performance. No carbs make more power than the big carbs you can buy today.
