Switching Mix Oil
87sheerips
Whats up, well I had a few cases of 7th gear semi-synthetic mix oil and Im finally out. I was thinking of getting a case of Klots benol for this winter season. Wondering who has run it, or what is better?? I want to run good shit, let me know
Thanks!!!! :beer:
ya i know ill get a million opinions, but is this klots benol good stuff?
Its good oil but I have seen alot of engines seize up from Klotz. Now that is just my expirence with the oil and alot of people here use it and sewar by it. I use Castrol 927.
Look up Klotz and Maxima Castrol and see witch one YOU think is the best.
Klotz Supertechniplate here. Dont run the Klotz Benol in cold weather. They say it starts to seperate from the fuel at temps around 35 deg F. It would be fine if you in the southern states though.
Here is a huge thead about oils. I just go the info from the manufactures web page.
Premix Page LINK
Another user of Klotz Super-Techniplate here. If you want opinions that you could actually stand by, I'd say call up the main engine builders over the U.S. and see what they use. We're all gonna have our opinion, and it's probably going to be w/e was used in the bike when we bought it or what someone recommended, and if it hasn't failed yet then it's probably good stuff, lol.
I personally run amsoil dominator at 50:1. I use to run castor 927 but after tearing my engine apart recently I switched to amsoil since it seems the castor oil doesnt burn clean at all. All oils have a btu rating on them which is how well it burns. I know amsoil has a +1 btu rating so it burns pretty good, im sure other oils out there have the same rating so check that out as well on whatever you decide to run.
