Ran the gas out of the carbs and a week later!
Ok two weeks ago I run the gas out of the banshee's carbs and last weekend I pulled it out to start it and it kick over and start but the idle is low and when I gave it throttle it just bogs down!!!!!! Anyone have any idea's on what could be up!!!
last night i took the carbs off and checked the gas lines and took the bottom of the carbs off and checked the Carb floats then i clean the carbs up with carb cleaner and put it all back together and now it won't even start! what do u think?
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
May be a dumb ?, and sry if it is, but did you give the bowls plenty of time to fill up after you turned the gas back on? I have to wait 2-3 minutes for mine to fill sometimes seems like before it'll start good. Otherwise I just kick and kick and kick and nothin.
As for the bogging, don't know what could've happened when you drained them that would change that. Something could be wrong with the floats and it may not be getting enough fuel, but you said you checked that.....
What do you mean by "run the gas out of the banshee's carbs" .. Do you mean you ran out of gas? If so, what conditions were you in when you ran out of gas? WOT? Just idling.. I would do a compression test and see what comes up... There's a small chance that if you were running it hard when you ran out, you could have damaged something... The bike will start to lean out as the bowls are emptied.. You're e-brake isn't on is it? Check out your compression and post the results..
Im going to say that its either A) the choke tube isnt on or B) the slides are in backwards.
I have done them both before and they are common mess ups, I would start there. Especially since it ran before you tore the carbs apart. The cut away on the slides should face the air filter.
It actually does sound like a problem my buddy had when he had his slides in backwards. It would run but was kinda stumbly and what not.
I'd check the slides to make sure they're in correctly, and also the choke tube. Also make sure you give the bowls plenty of time to fill, this will make starting it easier sometimes, or it's just one of those things that's good to do.
