peak-j Posted December 6, 2006 Report Share Posted December 6, 2006 Just wondering if the plastic cover by the sprocket, on the left hand side is a dealer item. Can you buy anything aftermarket that is aluminum or steel. Thanks for any input. What is the actual name of the part. Quote Link to comment Share on other sites More sharing options...
scooter Posted December 6, 2006 Report Share Posted December 6, 2006 stator cover is what your after. and no its not a dealer item many aftermarket places have them in chrome and every design you could want just depends on how much you want to spend Quote Link to comment Share on other sites More sharing options...
peak-j Posted December 6, 2006 Author Report Share Posted December 6, 2006 Guess I should have made that clearer sorry. I'm talking about the little cover behind the stator cover. It has three screws that holds it on a one little phillips head screw in the middle. Mine is cracked around the screws and is now leaking transmission fluid. Thanks Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 6, 2006 Report Share Posted December 6, 2006 he is talking about the cover for the shift drum... im looking on a oem repalcment chart and dont see it.,. ill keep looking and try to find a part number fr you Quote Link to comment Share on other sites More sharing options...
scooter Posted December 6, 2006 Report Share Posted December 6, 2006 if its under the stator cover and has three bolt holes right under the sprocket its the neutrel switch cover and yes there offered aftermarket too cascade has a nice chrome metal one for about 20 bucks Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 6, 2006 Report Share Posted December 6, 2006 (edited) i didnt see one listed on the oem replacment thing but if you got here http://www.cascadeinnovations.net/ click online store then select cascade banshee products... then go to neutral witch cover polished one for 21.00 bucks... why it is polished? i dont know you can see it any ways but what ever... im sure if you go to a dealer they got a part number for a plastic but the online oem replacment didnt have it listed sry.. if you can get a plaistc one id get that and then get your self a case saver... and it will cover that over anyways... Edited December 6, 2006 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted December 6, 2006 Report Share Posted December 6, 2006 Shift Drum Cover, Quicksand also has one. Click & scroll down the link.. http://www.quicksandmotorsports.com/accessories.htm Quote Link to comment Share on other sites More sharing options...
peak-j Posted December 6, 2006 Author Report Share Posted December 6, 2006 Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
yamahaD4L Posted December 8, 2006 Report Share Posted December 8, 2006 had the same problem with mine. the plastic holes were split and leaking a little. bought the cascade cover. would look good if you could see it. not worried about it splitting again though. Quote Link to comment Share on other sites More sharing options...
