one pipe smokes BAD
chevy7398
Your going to love this. You have to tear the bottom end appart. Pull the crank out, take the pto gear off and swap seals. You pretty much have to split the cases because the seal is sandwitched between the case halfs.
ya that is super, can i change the crank bearings my self or do i need to take it somewhere? also is there anything else i shoud check or change while im in there since this will be the second time i have had to take the motor out of the frame and stil havent goten to ride : ( i found a complete set of seals for the bottom end at albe but does anyone no of anyone with a complete set of bearings??
It's not the float bowls. Too much fuel does not cause oil to spew out the exhaust pipe.
Chevy, when you pull that pipe off, be ready, oil will dump out of it. Since you are going to be in the bottom end, I would as well suggest to weld and true the crank. Whoever you send it to for that can swap out bearings for you if necessary. If you plan on adding some major power down the road, you may as well pay the extra money and get the TZ and maxload bearings, or 2 TZ's if you really want insurance. I don't know of a bearing kit, but just check them all for smooth operation. Replace as necessary. I would also think about replacing the plastic impeller w/billet and possibly a pancake bearing.
ya when i pulled the pipe of a good amount ran out of it,pulled everthing of the side to se the bearing and erything looks good it must just be worn and leaking, my rod play is just enough to still be in spec but worn enough to get it done now, lowest cost for a rebuild kit for the crank 291 bucks plus lowest labor to rebuild it minus true and weld 120 bucks, so i am just going to get a new crankshaft, is it true i can get a hot rods crank trued and welded already for 400 bucks from fast? saw it on the site but seems to good to be true
both of my carb bowls are labeled 1-1, but one has a copper ball very small near the bottom
what side does that one go on.
im pretty sure they will only go on the correct carb due to the copper tube that stcks out of the bowl, though i am not sure, when i took mine apart i did them one at a time
Not sure how this question came up on this thread, but anyway... The bowls will bolt to either carb. I can't remember which has the ball but I want to say it is the right side bowl. To check though, spray some carb cleaner down the hole(in the bowls)that the copper tube would fit into. If it sprays out somewhere else, that is the bowl that goes on the choke pull side. The other bowl will spit the carb cleaner right back in your face, so whatch out! :biggrin:
Yea that sounds about right. That is just for the crank shaft. Hot Rods come welded but no the best. Have jeff at fast put down some extra weld. Ever thought about going with a +4mm long rod stroker. Might as well since your going to be replacing the crank anyway. Call Jeff at FAST good guy to deal with and he will discuse all the options.
josh
The carb bowl with the little BB goes on the Choke Knob (left side) carb!! It will be very hard to start cold if switched to the other side!!
