For trail riding, would it be better to use a stock crank or a plus 4mm crank? Advantanges of each?
Thanks,
Joe
you would be fine running a 4mil crank dor trials ... its when you get into cubs that arnt trail friendly.. run your stock jugs with a nice woods port and the 4mil and your goiing to have a nice combo under you...
Thanks,
Joe
How much of a power increase will I get from the 4 mm crank vs the stocker? Where can I get my stock crank refurbished and what will it cost me? The honda shop said they sent them off to get new bearings installed.
with minumal motor work to just accomidate a 4mm, your looking at about 7% gains... but anyone doing a stroker would be out of their minds to not get everything assosiated with it, i.e.
carbs reeds pipes head clutch the list goes on and on
If you only need bearings instaled thats fine but if you need a rebuild your better off getting an aftermarket crank. 4mills are nice. And I would go to a local builder 9 times out of 10 they are cheaper and just as good if not better than a honda shop.
I have the following done to my bike.
2001 Banshee
White
T-6 toomys
K and n filter
Boyseen reeds
Noss head
4 degree key
DG bumper and nerf bars
I was in the process of re ringing my banshee when I found the crank bearings were a little loose.
I would like to have the 4mm crank, but if I can get the stocker redone alot cheaper, I will proberly go that route. I don't really have any good local shops to go to, so does anyone know of one I can send it to and what it should cost more or less?
Thanks,
Joe
2001 Banshee
White
T-6 toomys
K and n filter
Boyseen reeds
Noss head
4 degree key
Thanks,
Joe
I had Vince at mrcrankshaft.com true/weld my stock crank for $65.00 and that included shipping back to me also. I live in texas and his shop is in Kentucky. He can also rebuild them, new bearings, etc. Great guy to work with, just give him a call.
