spring swap?
cam2
has anyone changed their rear shock spring themselves? if so, is it a biatch to do? i plan on getting an extended swingarm and i would like to put a stiffer spring on my shock so i was wondering if i have to send it out or could i do it myself without breaking any bones when it comes apart?
Do it yourself. Turn the preload all the way out. Get some spring compressors and tighten them a tad till your able to remove the spring plate at the bottom of the shock. Pull spring out. Now compress new spring and reassemble in reverse order. It's really simple.
do you need special spring compressors? or can you pick up some at an auto parts store? i've never dealt with large springs.
