The Faster Cracker Posted November 27, 2006 Report Share Posted November 27, 2006 ok so i was riding today and we have a table top at our place and she shfited fine through all the gears not that i ever got out of third much but she shifted fine. getting close to the end of the day so we started to screw around a bit and we started dragging. the first four or five times i could grab all gears but then the last few times i could not get out fo third no matter how hard i pulled up on the shifter. the only way i could was to chop the throttle and let the speed die a little bit and then it would shift. then i had a hard time again gettingout of fourth. my mods are in my sig the only diffrence is that i was given some c12 race fuel and used yamaha 2r instead of the motul and supreme i usually use. any ideas what is going on? :shrug: Quote Link to comment Share on other sites More sharing options...
lowriderb Posted November 27, 2006 Report Share Posted November 27, 2006 you may have bent a shift fork.. Quote Link to comment Share on other sites More sharing options...
Ting Ting Posted November 27, 2006 Report Share Posted November 27, 2006 You probly need to check the oil level. Mine did the same thing. Quote Link to comment Share on other sites More sharing options...
The Faster Cracker Posted November 27, 2006 Author Report Share Posted November 27, 2006 ok riddle me this, shee would still shift outta third when i was not under full power at the top of the rpm. would that still meant bent shift fork? oil level should be fine, i just changed it about 3 days before but ill look again. thanx for yalls help Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 27, 2006 Report Share Posted November 27, 2006 With a stock tranny, my banshee would do the same for a lot of the gears if I'm over-revving it. Are you using the clutch when shifting? Quote Link to comment Share on other sites More sharing options...
The Faster Cracker Posted November 27, 2006 Author Report Share Posted November 27, 2006 yeah i was pullin git in all the way. however, when it was going through all the gears i would just barely pull the clutch in and it would grab the next gear. could that have been the culprit? Quote Link to comment Share on other sites More sharing options...
