Jet kits
Satsol67
I am looking for a jet kit for my stock carbs. Where is the best place to get a kit that has different ones to choose from? Or do I have to specify which sizes I want? Its getting to be a pain to start so I think I should go up in the pilots I'm at 25 now and 280 for mains. Now thats it getting colder I would like to go up on each one.
What would be recomended? 27 on pilots and 300 on mains?
300-320 mains, 27.5 pilots, needle in the middle, air screws 1 and a half turns out. 280's seem really small.
yes, what he said. also, whats your location? you ought to bump the compression up a little more, your leaving hp on the table still, even with pump gas.
call carbparts.com and order a 27.5 and a 30 pilot. then order a 290, 300, 310 and 320 main jets. that'll be cheaper than a 'jet kit' and you won't be buying stuff you don't need.
chances are, you'll be int he 310 range, with a 27.5 pilot; needle in the 4th clip.
Edited by sredish
I'm in the upstate South Carolina area elevation is around 1000 above sea level. I have been thinking about going to 20cc domes but would that bring up my compression to much? Its at 140 now. I want to stick with pump gas 93 oct.
hey, i live in upstate s.c. to. i have pretty much the same setup with 290 mains, 27 pilots, and needle in 3 slot. the only thing is those 20cc domes you want to run. that may push you pretty close to a race mix. thats something you will just have to play with. you sould be alble to run them with no problem.
Edited by BANSHEEMANIAC
