'01 Banshee 7mil Cub
:mad: Darn bills.
Yamaha banshee for sale. A&S built 7mm stroked 68mm bore (443cc) utilizing new pistons, rods, crank, etc. Crank has been welded. Case has been match ported, with just a clean-up port on the cylinders. V-Force 3 reed cages, 40mm Mikuni carbs and CPI Big Bore pipes. This engine has less then 20 hours on it. Shift star was modded and the flywheel lightened. Adjustable timing plate, aftermarket clutch basket (don't remember the brand, I'm useless). There's other things, but just too much for me to remember it all right now. Dan rebuilt the entire engine for me and beefed-up what was needed.
Frame is stock Yamaha, power coated a translucent dark red. A-arms are +2+1 Quicksand. +6 swinger is also a Quicksand. A set of dirt tires and the sand tires you see in the pics are included. The paddels are 9 flapper Taller-Haulers and a set of 10 flapper Haulers are included as well.
Those of you who know me are aware that I had some trouble getting the motor tuned in after I got it back from A&S. I changed carbs from the stupid 35mm Keihns and went to the Mikunis. Bike runs like a raped ape now. I recently had the head off of her to check the carbon patch. It looks good and the cylinder walls look like new. To sell my baby pains me more than I can put into words. There may be some things that I'm missing, please PM me with any questions.
$5500 obo.
Edited by ScrewMachine
