cexualcensations Posted November 22, 2006 Report Share Posted November 22, 2006 I have two banshees that I am working on (one for drag and the other for mx and playing around on). The drag one a am planning on building a massive cheetah stroker as I talked about in a previous post. That bike I oringially had was intended for a drag / trail bike with a 421 cheetah /4mm stroker. So I sent the top crankcase and had them machined to accept the larger cylinder . Well since then i have picked up another banshee and have changed my mind. I want strickly a drag bike and a mx bike. So with that said since I want to go bigger for the drag bike like a 593/610 the lower cases will have to be trenched and expoxed which will cost around 600 from rdz racing. And the other banshee which I have had a mx port done to the stock cylinder along with a ton more upgrades needs a new crankcase which cost 500. So I was wondering If I could use the case which has been machined for the larger cheetah cylinders with the stock cylinder for my mx bike. Cause I am thinkin about buying billet case for the drag bike for duribility and in the long run it will save me money. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted November 22, 2006 Report Share Posted November 22, 2006 Yes you can use the machined cases on the mx bike, you would be better off buying a set of billet cases for the big drag motor. Quote Link to comment Share on other sites More sharing options...
420 RACING Posted November 22, 2006 Report Share Posted November 22, 2006 Yup just what he said....Just get the billet cases :thumbsup: Quote Link to comment Share on other sites More sharing options...
cexualcensations Posted November 24, 2006 Author Report Share Posted November 24, 2006 So it will not affect the performance by putting stock ported cylinders on the machined cases Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted November 24, 2006 Report Share Posted November 24, 2006 It will be not noticable. You will be changing case volume by such a small amount, that it really will not matter. Quote Link to comment Share on other sites More sharing options...
