reggie Posted November 17, 2006 Report Share Posted November 17, 2006 would cracked reeds cause this? the topend has about 5 rides on it i just changed spark plugs , flushed and changed antifreeze, cleaned and oiled the air filters(34mm with clamp ons) repacked the silencers, cleaned both carbs very good. my banshee has bottum and midrange but as soon as i hit powerband it breaks up and pops everytime. its not smoking and the plugs are burning brown. do have any ideas????? Quote Link to comment Share on other sites More sharing options...
Meat Posted November 17, 2006 Report Share Posted November 17, 2006 I don't trust plug colors. my first instinct is jettig. You could on the right track with the reeds too. So rip off the carbs and check the reeds, if the reeds are all intact, then put some bigger main jets in the carbies and dial her in. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 17, 2006 Report Share Posted November 17, 2006 What kind of carbs do you have, and what is your current jetting, mods, and elevation? josh Quote Link to comment Share on other sites More sharing options...
shanYE west Posted November 17, 2006 Report Share Posted November 17, 2006 mabye electrical? check coil and Pick-up coil gap.. Quote Link to comment Share on other sites More sharing options...
DVS1 Posted November 19, 2006 Report Share Posted November 19, 2006 mabye electrical? check coil and Pick-up coil gap.. After I installed a lightened flywheel, I forgot to check pick-up coil gap and had a very similiar situation. Closed the gap down and ran fine. G/L Quote Link to comment Share on other sites More sharing options...
