Loose axle!
DaFish
my axle is loose you can grab it and move it from side to side not much but a lil bit probbly about a 64th of an inch. is this bad normal or what and can you let me know how to fix it thanks. and i can move my rotor around.
Edited by DaFish
If it moves side to side its your locknuts probably. If it moves up and down its your bearings. Easy to replace. Buy a rear axle bearing kit. Hammer out the old onces. Pack the new ones with good greese and put em in the carrier, pack the seals with grease, put them on. put the axle on. Go ride.
stock i think is 32mm
not left handed thread........
might try some blue loctite (med strength)
they also make an activator for loctite speeds up curing time and also preps surface for a good bond.......
red is high strength usually takes heat to break loose........... :beer:
