BrianEb Posted November 14, 2006 Report Share Posted November 14, 2006 I been taking my shee to some local practice tracks here in MI. i.e. (Sandbox, and Pro Source indoor) Well the first year I went to Baja MX in Michigan and that track beat the Shit out of me with stock suspension. So I upgraded to SoCal +2 +1 arms and Elkas. My arms still took a little bit of a beating upgraded to the Faast Flex Bars. They seem to help trememdously. What should my next step be to help smooth out the Banshee ride. Here is what I have so far. Quote Link to comment Share on other sites More sharing options...
djackbanshee Posted November 14, 2006 Report Share Posted November 14, 2006 Single carb !!!! Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted November 14, 2006 Report Share Posted November 14, 2006 Yup, a good single carb are a great addition for MX and good low end pipes like PTR.Also put a extended axle RPM are the best.Just with that stuff you are in good way Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted November 14, 2006 Report Share Posted November 14, 2006 You can get away a lot cheaper on the axl, check out the G Force on Rocky Mountain, also depending on the terrain, you could always go with a -1 swinger, should give you a little more bit. Also go with the typical low end mods, timing advance, milled head or cool head. Definately gonna neeed an MX port job too! Don't forget reeds. I think it is worth it, I don't run MX but I do run trails, and even with my limited mods, I can out run piped YFZs and 450rs. Get some good tires, and I don't think you'll be dissapointed at all. Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted November 15, 2006 Report Share Posted November 15, 2006 invest in some good shocks before you do anything else. The engine power will do little for the problems you are describing. Concentrate on the suspension then do the engine mods. I highly reccomend the PEP ZPS shocks, or the Elka's. Install a -1.5 swingarm to move the center of gravity back, plus install some AC nerf bars with the pegs moved back and down. Both of these items will help tremendously with the handling of the bike. AFter all of this then find some used YFZ spindles and hubs and brakes and install them. The spindles from the YFZ will allow quicker turning and better all around handling. Or do the ultimate and buy a Lonestar Outlaw Chassis like mine and be done with it. 250R geo frame and ZPS shocks, there is not a better handling Banshee out there. The 250R geo is what makes the difference. PM me if you have any other questions. He doesnt need better shocks he says he has Elkas Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted November 15, 2006 Report Share Posted November 15, 2006 invest in some good shocks before you do anything else. The engine power will do little for the problems you are describing. Concentrate on the suspension then do the engine mods. I highly reccomend the PEP ZPS shocks, or the Elka's. Install a -1.5 swingarm to move the center of gravity back, plus install some AC nerf bars with the pegs moved back and down. Both of these items will help tremendously with the handling of the bike. AFter all of this then find some used YFZ spindles and hubs and brakes and install them. The spindles from the YFZ will allow quicker turning and better all around handling. Or do the ultimate and buy a Lonestar Outlaw Chassis like mine and be done with it. 250R geo frame and ZPS shocks, there is not a better handling Banshee out there. The 250R geo is what makes the difference. PM me if you have any other questions. FYI YFZ calipers will fit on stock hubs, I have never heard of the YFZ spindle and hub swap, not sure how that would work? Got a link about that, I'd be interested in seeing how that works. Quote Link to comment Share on other sites More sharing options...
