robeport Posted November 10, 2006 Report Share Posted November 10, 2006 Here is what I currently have: Bored .040 Dune Port V-Force 3 Reeds Cool Head 19cc Domes T-5 Pipes Timing Plate @ +5 Will have Dyna FS With this current set up, what carbs should I be looking at? Would 35PWK's or 34PJ's be too large? Eventually I would like to go with a cub, so I am gradually accumulating all the parts I will need. That being said, I don't want to get carbs that will work well with the cub but run like ass with my current motor. Any suggestions? Quote Link to comment Share on other sites More sharing options...
sheefreak Posted November 10, 2006 Report Share Posted November 10, 2006 The 34, and 35's will work w/your motor and be great for top end but at the expense of throttle response. I would say some 30's would be just about perfect for your setup. But since you are going to be upgrading I think I would go w/the 35's. Quote Link to comment Share on other sites More sharing options...
odaen Posted November 10, 2006 Report Share Posted November 10, 2006 Here is what I currently have: Bored .040 Dune Port V-Force 3 Reeds Cool Head 19cc Domes T-5 Pipes Timing Plate @ +5 Will have Dyna FS With this current set up, what carbs should I be looking at? Would 35PWK's or 34PJ's be too large? Eventually I would like to go with a cub, so I am gradually accumulating all the parts I will need. That being said, I don't want to get carbs that will work well with the cub but run like ass with my current motor. Any suggestions? Cubs really like large carbs. I ran 39PWK's on my 4mm and actually picked up 3HP switching from 36PWK's. I'd say to stick with your stock carbs for now and buy some larger ones when you get your cub. Quote Link to comment Share on other sites More sharing options...
r/atvshee Posted November 10, 2006 Report Share Posted November 10, 2006 or you can just get the carbs bored out in the future Quote Link to comment Share on other sites More sharing options...
robeport Posted November 10, 2006 Author Report Share Posted November 10, 2006 Would 33 PWK's be a good compromise? Quote Link to comment Share on other sites More sharing options...
odaen Posted November 10, 2006 Report Share Posted November 10, 2006 Would 33 PWK's be a good compromise? get some 30pwk's (28 bored to 30) for your current motor..... when you put your cub together, sell them (take the $100 loss) and buy some bigger carbs Quote Link to comment Share on other sites More sharing options...
sheefreak Posted November 10, 2006 Report Share Posted November 10, 2006 I would say no. As Odaen explained, as I have heard many times that cubs like a big carb. A 35 will work w/the cub, w/a 33 you are really going to be restricting that motor. Either go w/the 35, as it will be pretty good for both, or follow Odaen's suggestion. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 10, 2006 Report Share Posted November 10, 2006 I ran 34mm PJ's with my mods in my sig. It ran good. I just bought a set of PWK 33mm carbs now. I have put them on yet, but they should do just as good. Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted November 11, 2006 Report Share Posted November 11, 2006 I run 33 PWKs on two of my shees. Both are ported. Great carb. When you get the cub just sell the 33's and move on up. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 11, 2006 Report Share Posted November 11, 2006 i say stick with stock carbs for now and buy bigger ones when you get your cubs. stock carbs actually perform very well on stock and ported motors... Quote Link to comment Share on other sites More sharing options...
