rynb15 Posted November 10, 2006 Report Share Posted November 10, 2006 My thumb throttle is a little on the stiff side. After a couple hours of ridding i can barley push it in my thumb hurts so bad. :: Sorry if its a dumb question. Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted November 10, 2006 Report Share Posted November 10, 2006 call jeff at fast he can get softer springs for the carbs Quote Link to comment Share on other sites More sharing options...
djackbanshee Posted November 10, 2006 Report Share Posted November 10, 2006 Put a honda thumb throttle Quote Link to comment Share on other sites More sharing options...
rynb15 Posted November 10, 2006 Author Report Share Posted November 10, 2006 thanks guys, ill look into both. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted November 10, 2006 Report Share Posted November 10, 2006 Single carb :biggrin: Quote Link to comment Share on other sites More sharing options...
okbeast Posted November 10, 2006 Report Share Posted November 10, 2006 Same problem here man. I called Jeff and I don't think he had softer springs for the stock carbs (which is what i have, didn't look at your sig). I'm going to cut my stock springs to see if i can soften it up some. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted November 10, 2006 Report Share Posted November 10, 2006 Also the extended thumb levers work great too. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 10, 2006 Report Share Posted November 10, 2006 I have a thumb throttle extender if someone wants to give me 10 bucks for it, including the ride. It's just sitting in my tool box, I bought a brand new SRP complete thumb throttle. This is the one I got: http://www.rockymountainatv.com/productDet...mp;navType=type Quote Link to comment Share on other sites More sharing options...
csrmel Posted November 10, 2006 Report Share Posted November 10, 2006 take off the throttle cable and lube it up really good while working the cable in and out. next lube the handlebar thumb assembly and make sure that moves with no resistance. finally i have had good luck cutting 3 coils off my stock springs in the carbs. makes the thumb throttle about as touch as a raptors (which isnt tough at all). Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted November 11, 2006 Report Share Posted November 11, 2006 I have a thumb throttle extender if someone wants to give me 10 bucks for it, including the ride. It's just sitting in my tool box, I bought a brand new SRP complete thumb throttle. This is the one I got: http://www.rockymountainatv.com/productDet...mp;navType=type Have you tried it out? How does it work? If the offer still stands I'll take it off your hands for my 01. Thanks. Bob Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 11, 2006 Report Share Posted November 11, 2006 I ended up buying a whole new throttle assembly, wanted a nice new one that was adjustable too. The few times I used it, it's ok.... Let me look in my toolbox/box of parts and I'll PM you the details. I can ship on Monday, if you'd like..... :beer: Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted November 11, 2006 Report Share Posted November 11, 2006 Thanks. PM me your addy and I'll send out the check today. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 12, 2006 Report Share Posted November 12, 2006 Just a tip, if you cut some off of your stock springs stretch them back out to the original length. :beer: Also works pretty good to roll them around and around on a sander/grinder to sand down the wire diameter But not too much. Quote Link to comment Share on other sites More sharing options...
Uncle Stashu Posted November 12, 2006 Report Share Posted November 12, 2006 Just a tip, if you cut some off of your stock springs stretch them back out to the original length. :beer: Also works pretty good to roll them around and around on a sander/grinder to sand down the wire diameter But not too much. I was always under the impression that removing material from the wire diameter (second method described above) was the way to go. :thumbsup: Quote Link to comment Share on other sites More sharing options...
okbeast Posted November 13, 2006 Report Share Posted November 13, 2006 Just a tip, if you cut some off of your stock springs stretch them back out to the original length. :beer: Also works pretty good to roll them around and around on a sander/grinder to sand down the wire diameter But not too much. If you were to do this and didn't get both springs the same would there be any problems in the carbs not syncing up? Quote Link to comment Share on other sites More sharing options...
