bansheefreestyler Posted November 3, 2006 Report Share Posted November 3, 2006 hey guys. I just bought an engine off ebay since my tranny was shot in my other one. Well i was checking it out and the one rod seemed a little stiff. I put it together anyways figuring it would be fine. Well i started it up and it started good then there was a pop and something shot out the exhaust and now it wont fire. only the good side will. if the crank bearing seized what damage would be done? will my cylinders be pooched? let me know. Thanks BFS Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted November 3, 2006 Report Share Posted November 3, 2006 I have seen a set of cylinders that when the rod bearing let go it busted the cases the cylinder and the rod :sad: not a good thing at all. I would pull it down asap and get it checked out! Quote Link to comment Share on other sites More sharing options...
odaen Posted November 3, 2006 Report Share Posted November 3, 2006 hey guys. I just bought an engine off ebay since my tranny was shot in my other one. Well i was checking it out and the one rod seemed a little stiff. I put it together anyways figuring it would be fine. Well i started it up and it started good then there was a pop and something shot out the exhaust and now it wont fire. only the good side will. if the crank bearing seized what damage would be done? will my cylinders be pooched? let me know. Thanks BFS should've never put your cylinders on that bottom end. you won't know what kind of damage to expect until you pull it apart. I'd almost expect your cylinder walls to be nice and gouged up, and if you toasted a piston, your head is gonna have some pits in it too. Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted November 4, 2006 Author Report Share Posted November 4, 2006 thanks for the replies guys. i have another set oy cylinders and a spare bottom end. so i just need to get my mechanic to do the work. hopefully its not a huge problem Quote Link to comment Share on other sites More sharing options...
