NEVER SATISFIED Posted March 20, 2007 Report Share Posted March 20, 2007 you have stock carbs on that!!? Quote Link to comment Share on other sites More sharing options...
camatv Posted March 20, 2007 Report Share Posted March 20, 2007 i always thought it would be fun to do a full stocker banshee pipes and all.. you can cut the stocker ignition plate and get the 4 d advance they like. stock cages with boyesen reeds. head milled air box mods port changes. ( dont always trust those programs.) make it a mid range motor.. port it for mid range get the porting matched to the stock pipes and take advantage of the better bottom end they have over ANY aftermarket pipe. ( yes i said it stockers make more bottom to mid than other pipes..) do that and it should ( well it BETTER!) run a lot better than stock! what about a 68mm +4 stroker on stocker pipes...?? he he.. 55hp on stock pipes i also think is a stretch.. but it might happen? ole banshee's are starting to get cheap enough i might just get it done some day.. that would shut those yfz guys up huh.. getting beat by a stock pipes quiet full air box banshee.. Quote Link to comment Share on other sites More sharing options...
