MoBanshee Posted October 27, 2006 Report Share Posted October 27, 2006 Well guys I'm at wits end with my 89' Banshee. I just put it back together 2day (topend) and be4 I even started the damn thing up, its leaking collant outta some hole way up in the motor and the hole is from damage, its a factory made hole . WHATS UP???? Quote Link to comment Share on other sites More sharing options...
nicktoney Posted October 27, 2006 Report Share Posted October 27, 2006 it isnt in the side of the jug is it? threaded on the inside? hope not :: just checking, im sure you knew about the plugs there.... other than that, idk? Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 27, 2006 Author Report Share Posted October 27, 2006 Well guys I'm at wits end with my 89' Banshee. I just put it back together 2day (topend) and be4 I even started the damn thing up, its leaking collant outta some hole way up in the motor and the hole is from damage, its a factory made hole . WHATS UP???? The hole is in th e jug and I didnt know about any plugs, please tell me. Thanks. Quote Link to comment Share on other sites More sharing options...
87banman Posted October 27, 2006 Report Share Posted October 27, 2006 there should be a bolt in that hole.....on both jugs Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 27, 2006 Author Report Share Posted October 27, 2006 there should be a bolt in that hole.....on both jugs wHERE SHOULD THE BOLT BE ON BOTH JUGS BECUZ ITS NOT LEAKING FROM THE JUGS IT LOOKS LIKE ITS DRIPPING OUTTA A HOLE IN THE BOTTOM CASE I CAN SEND U PICS IF U WANT wHERE SHOULD THE BOLT BE ON BOTH JUGS BECUZ ITS NOT LEAKING FROM THE JUGS IT LOOKS LIKE ITS DRIPPING OUTTA A HOLE IN THE BOTTOM CASE I CAN SEND U PICS IF U WANT CAN SOME BODY PLEASE CALL ME I NEED HELP BAD BAD BAD #(734)323-7392 JAYSON MICHIGAN Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted October 27, 2006 Report Share Posted October 27, 2006 wHERE SHOULD THE BOLT BE ON BOTH JUGS BECUZ ITS NOT LEAKING FROM THE JUGS IT LOOKS LIKE ITS DRIPPING OUTTA A HOLE IN THE BOTTOM CASE I CAN SEND U PICS IF U WANT CAN SOME BODY PLEASE CALL ME I NEED HELP BAD BAD BAD #(734)323-7392 JAYSON MICHIGAN the coolant is defanitley running down to the bottom of the case cause there are no coolant ports in the case its self clean it off and check the cyl head and the two bleed holes on both sides of the stock cyls.. Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 27, 2006 Author Report Share Posted October 27, 2006 the coolant is defanitley running down to the bottom of the case cause there are no coolant ports in the case its self clean it off and check the cyl head and the two bleed holes on both sides of the stock cyls.. ITS NOT COMING FROM THE CYLINDER ANYWHERE YOU HAVE TO GET ACTUALL ALL THE WAY UP UNDER THE QUAD TO SEE IT AND THE ARE 2 RODS DOWN THERE BOLTED TO THE FRAME AND IF U LOOK AT THE LEFT ROD FRONT SCREW AND THEN LOOK PAST THAT UP TO AHOLE IN THE CASING AND ITS LEAKING FROM THERE. CAN YOU PLEASE CALL ME SO I CAN EXPLAIN. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted October 27, 2006 Report Share Posted October 27, 2006 post pics Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 27, 2006 Author Report Share Posted October 27, 2006 :shoothead: post pics THE PICS I HAVE OF IT ON MY COMPUTER ARE TO LARGE TO UPLOAD HOW DO I SHRINK THEM DOWN TO FIT THIS PAGE? Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted October 27, 2006 Report Share Posted October 27, 2006 :shoothead: THE PICS I HAVE OF IT ON MY COMPUTER ARE TO LARGE TO UPLOAD HOW DO I SHRINK THEM DOWN TO FIT THIS PAGE? Email them to me if you don't know how I will pm you my email Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 27, 2006 Author Report Share Posted October 27, 2006 Email them to me if you don't know how I will pm you my email COOL MAN ILL SEND THEM TO U RIGHT NOW SEND YOUR EMAIL TO motorcityrudeboy@yahoo.com Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted October 27, 2006 Report Share Posted October 27, 2006 COOL MAN ILL SEND THEM TO U RIGHT NOW SEND YOUR EMAIL TO motorcityrudeboy@yahoo.com ITS LEAKING FROM THE HOSE ON THE TOP OF THE CASE FROM THE HEAD TO THE CLUTCH COVER AND RUNNING DOWN THAT LITTLE HOLE IN THE CENTER OF THE CASE THE HOSE RUNS IN BETWEEN YOUR CARBS Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 28, 2006 Author Report Share Posted October 28, 2006 ITS LEAKING FROM THE HOSE ON THE TOP OF THE CASE FROM THE HEAD TO THE CLUTCH COVER AND RUNNING DOWN THAT LITTLE HOLE IN THE CENTER OF THE CASE THE HOSE RUNS IN BETWEEN YOUR CARBS MAN U ARE BRILIANT CAN U PLEASE GIVE ME A CALL U ARE RIGHT FOR SURE I THINK PLEASE GIVE ME A CALL Quote Link to comment Share on other sites More sharing options...
JET 99 Posted October 28, 2006 Report Share Posted October 28, 2006 if you take off your seat and look down between carbs at an angle there is a drain hole that goes thru upper and lower case half you have a hose that runs back down in real close to the back of cylinders. you probably will find your leak there :beer: Quote Link to comment Share on other sites More sharing options...
MoBanshee Posted October 28, 2006 Author Report Share Posted October 28, 2006 if you take off your seat and look down between carbs at an angle there is a drain hole that goes thru upper and lower case half you have a hose that runs back down in real close to the back of cylinders. you probably will find your leak there :beer: :: MAN I HAVE PICS OF EXACTLY WHATS GOING ON BECUZ THERE IS NO HOSE THERE IF YOU DONT MIND TAKING A LOOK SEND YOUR EMAIL ADDRESS TO ME AT motorcityrudeboy@yahoo.com BECUZ THE PICS ARE TO LARGE FOR THIS SITE. THANKS MY NAME IS JAY Quote Link to comment Share on other sites More sharing options...
