excess Posted October 26, 2006 Report Share Posted October 26, 2006 besides cutting the springs, what do you guys recommend to soften up my throttle, i have mikuni 36 flat slides. Ive tried and hate those easy push throttles. I just wanted to see what you guys recommended to do before i did it. Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted October 27, 2006 Report Share Posted October 27, 2006 besides cutting the springs, what do you guys recommend to soften up my throttle, i have mikuni 36 flat slides. Ive tried and hate those easy push throttles. I just wanted to see what you guys recommended to do before i did it. nothing dont cut the slide springs most guys use a twist i hate them but thats what most guys do a set of 36 mm mikuni t carbs shouldent be all that bad i got 41s on mine with no prob check your cable routing and pull your cable and actuate it by hand make sure you dont have a stiff cable Quote Link to comment Share on other sites More sharing options...
Tedder Posted October 27, 2006 Report Share Posted October 27, 2006 If you find the cable is OK Jeff at F.A.S.T Racing can set you up with softer springs. Quote Link to comment Share on other sites More sharing options...
ranshee Posted October 27, 2006 Report Share Posted October 27, 2006 Remove the return spring in the throttle housing. That helped mine a bit. Quote Link to comment Share on other sites More sharing options...
excess Posted October 28, 2006 Author Report Share Posted October 28, 2006 does f.a.s.t have a site? or can you give me the number? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted October 29, 2006 Report Share Posted October 29, 2006 Fast racing site;http://www.farmandsandtoys.com/ Quote Link to comment Share on other sites More sharing options...
