Swapped to no TORS carbs and won't idle
Toybreaker
Ok I read the FAQ
But, is there another way to get the idle adjustment without removing material from the carb bodies?
Here is the skinny
1988 64.25mm bore, stock stroke
welded and trued crank
V-Force 2 reeds
stock carbs with tors eliminated idle screws all the way in, cables adjusted all the way out everywhere it can be adjusted
cool head with 20 cc domes
jetting as follows
320 mains
27.5 pilots
stock needle at 2 slot from blunt end
plug chop shows proper jetting
no bog anywhere just a little soft on the bottom end. Screams on top.
Is there something electrical i am missing with the tors elctrical stuff?
The idle screws are drilled. They are screwed all the way in. Pull the slides and the brass tit is almost .3(about 9mm for you metric types) into the slide's bore. The throttle cable adjustment at the handlebars is all the way out, the tops of the carbs is all the way out. I don't understand it.
going from 25 all the way up to 32.5 pilots has made no difference. It runs the best with 27.5's
the needle has no bearing on the idle circuit but i played with it too. 2nd slot for the blunt end runs the best. Still won't idle. I am tempted to put my TORS carb set up back on. It idled.
I went through the carbs before i installed them. blew all the passages with brake cleaner and compressed air. Made sure the jets were clean and gunk free. Mechanically nothing is wrong. I really hate having to play with the throttle to keep it running while i am sitting still.
Where the idle screws were drilled and tapped for, the bore is at an angle. You can mille or flatten it to be perfectly at a 90. For a start to set the idle, look down in the carb with the cap off and when the tip of the idle screw is just flush then do 2 full turns on the idle screw. I got that from tip from one the the hqer here. Always adjust evenly.
Guest nightmare
I had the same problem. Just had to remove more material from the side of the carb to get the screw to go in farther. An easy way to tell if this is your problem is take the locknut off of the screws. This will alow you to run the screw in a little more. If that works then you know you need to file it down some more.
