Compression
I was wondering what or how to guage the compression difference from altitude to altitude. I was recently at Sand Mountain Nevada and i checked my compression up there and it was 145-150 lbs what should it be in Santa Rosa California which is probably close if not sea level. and what is safe to run my compression to with out blowing up the motor. i heard to run it between 175 and 200 lbs with race gas would be just fine any suggestions.
The only way to be sure of your compression is to take a gauge with you and use the 14mm adapter the 18mm adapter is to big it will hit the top of your piston. From what I hear 165-170 is where you start having to use race gas probably 50/50. Ide check that Im not 100% on it. If I were at 200 I would definatly run straight 110 and get a new crank and get added welds or just get you stock crank trued and welded. 200lbs of compression is alot.
I could be wrong but it shouldnt vary more than 15 psi. I think sea level is 14.7psi and the further you go up in the atmosphere the less it gets. I dont know the elevation of sand mountain but lets guess it is higher than Santa rosa, your readings there will be lower than your results in cali.
Here is a compression chart.................
Approximate Cranking Compression
These pressures are estimates based on fresh stock bore, piston, porting, and deck height.
It is recommended to check your compression after installation.
Sea Level 1000' 2000' 3000' 4000' 5000'
18cc 197 178 171 170 165 145
19cc 183 167 160 158 152 137
20cc 169 156 149 146 140 129
21cc 156 145 138 134 128 121
stock 130 125 118 112 106 100
Sand Mountain Nevada is at approximately 4000-4500' depending on where you are at. So on stock bike the difference is approximately 33 #'s and on a modified bike the difference is more drastic 42 #'s. But you need to check it at either end............... :beer:
