what size carb should i use
charles
im not sure what size should be better a 35mm or 38mm ihave ported cylinder, cool head, v-force 3, t-5, +4 timing plate. I realy like the 2 into 1 seeting and i want to stick with that!!!! but can you please help me on the size ???? thank you your help is appreciated.
I'm gonna "co-sign" and agree with those posted above....
Unless you have a drag port on your shee, then I'd go 38. (Actually I'd go with a pair of 39's with a drag port, but....that's just me.)
I don't think you can go wrong. Just keep in mind, with one carb feeing two cylinders, you traditionally have to go a LOT bigger on the main than you would in a twin setup. Say around 185 to 190ish....
