Skidmark Posted October 20, 2006 Report Share Posted October 20, 2006 I've always heard that the more air you put in haulers the better they hook up.... How much is too much? What amount have you guys found that works the best? Quote Link to comment Share on other sites More sharing options...
yfzdunegirl Posted October 21, 2006 Report Share Posted October 21, 2006 I've always heard that the more air you put in haulers the better they hook up.... How much is too much? What amount have you guys found that works the best? There's another active thread about this right now. Plus there's about 50 others if you try searching. But in the effort to save you time: 5psi minimum if you're jumping at all, 8 psi max. Vary the pressure based on sand conditions. Really dry, loose sand needs lower psi, wet sand needs higher psi. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 22, 2006 Report Share Posted October 22, 2006 i run 4 lbs and its great... hooks up in everything Quote Link to comment Share on other sites More sharing options...
535banshee Posted October 22, 2006 Report Share Posted October 22, 2006 (edited) There's another active thread about this right now. Plus there's about 50 others if you try searching. But in the effort to save you time: 5psi minimum if you're jumping at all, 8 psi max. Vary the pressure based on sand conditions. Really dry, loose sand needs lower psi, wet sand needs higher psi. this is not correct! if you want more traction you put more air in a paddle tire. this keeps the paddle from rolling over. less air in a paddle tire lets the paddle roll over. we run more than 8psi in a paddle tire all the time in drag racing. air pressure will very due to the type of sand. loose sand you want more air to get the tire to hook. wet sand hooks better so if you are hooking to hard than let some air out Edited October 22, 2006 by 535banshee Quote Link to comment Share on other sites More sharing options...
Skidmark Posted October 24, 2006 Author Report Share Posted October 24, 2006 There's another active thread about this right now. Plus there's about 50 others if you try searching. Yeah, sorry. :shrug: Quote Link to comment Share on other sites More sharing options...
noslo98 Posted November 1, 2006 Report Share Posted November 1, 2006 I run 4psi in my extremes and feels perfect, I dont really want it hooking up any more than what it is now.I am too cheap to put a swinger on the bike so it makes it nice and unpredictable. Quote Link to comment Share on other sites More sharing options...
headsup Posted November 7, 2006 Report Share Posted November 7, 2006 I run 4psi in my extremes and feels perfect, I dont really want it hooking up any more than what it is now.I am too cheap to put a swinger on the bike so it makes it nice and unpredictable. I run 3 psi in the loose sand, however i noticed i am starting to spin the tire a little bit on the rim. Quote Link to comment Share on other sites More sharing options...
SandShots Posted December 7, 2006 Report Share Posted December 7, 2006 loose sand run more psi. packed sand run low psi. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted December 7, 2006 Report Share Posted December 7, 2006 Yeah spinnin' that tire on the rim is not to helpful. I think that the 6-8 pounds in loose sand works pretty good, because the blades do roll if not inflated enough.............. :beer: Quote Link to comment Share on other sites More sharing options...
SandShots Posted December 7, 2006 Report Share Posted December 7, 2006 Yeah spinnin' that tire on the rim is not to helpful. I think that the 6-8 pounds in loose sand works pretty good, because the blades do roll if not inflated enough.............. :beer: will the bead glue work? or is that just for preventing leaks? Quote Link to comment Share on other sites More sharing options...
