Banshee alky carb cable
AustinONeal
i got some 35.5 mm alky carbs and i was told i need a different cable so, can anyone link me where i need to go.. i asked on Planet sand and no one could help me. I know you guys always are really quick about helping out, so i should have asked here 1st.
i got a stainless terry cable from hy-tech atv. it was a little under 50 bucks http://www.hy-tech-atv.com/ john at sandtoyz unlimited could probably give you a killer deal on one too http://sandtoyzunlimited.com
Austin, it should take the same cable that stock carbs use WITH the tors system removed . YOu might need the taller adjusters to get full throttle. Look on our website to see what they look like.
well thats the thing i couldnt get the longer adjusters that the alky carbs so i used the stock adjusters but yea that sucked to i had some 39mm alkys and tried to use the stock cable and the cable wouldnt let the slide go down all the way. and i didnt want to run into the same problem so i used the stockers.
But i was told about a longer cable, the alky adjusters are what is killing me but my stock carbs are 35mm so i dont see why i couldnt just use the stock cable
But it has taller adjusters looks like a kehin jet on top of it
if youve been running these carbs already and they open up to wot then you dont need a different cable.. if havent ran them yet i would suggest getting a terry cable..
well i want to buy a whole new cable system for the alkys im going to do that...
so jeff link me a complete full alky cable
theres no special "alcohol throttle cable" for carbs, there are only throttle cables.. if you havent been running these carbs yet, i would get a terry cable and be done..
the motion pro cables you could get may end up needing the longer adjusments for the carb tops..
either one you get make sure your carbs are in sinc and open fully (where the slide is completly out of the way of the neck of the carbs)
either which cable you get you can pick them up from a veriety of venders or pretty much any builder you could name can get it for you in the 50-70 range..
