jbooker82 Posted October 12, 2006 Report Share Posted October 12, 2006 I was wondering if any body has had any problems with there Toomey T5's not fitting right. The RH side on my banshee fits perfict. The LH side stinger tube hits on the frame. I was wondering if this is a fluke or if they are just that way. My FMF SST's aslo rubbed on the frame the same way. Is there any fix becides bending someting? Also since it hits on the frame i had to flip the silencer mount. The little aluminum piece that bolts to the silencer and sub frame is now on the out side. Thanks for any ideas josh Quote Link to comment Share on other sites More sharing options...
okbeast Posted October 12, 2006 Report Share Posted October 12, 2006 I didn't look that close at mine when I took them off but I don't think there was any fitment issues. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 12, 2006 Report Share Posted October 12, 2006 If Im understanding correct the silencer tab mounts thru the outside of the frame. Are the silencers on the wrong side? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 12, 2006 Author Report Share Posted October 12, 2006 The LH side hits on the frame, right about where the carbs are. The first tube that the stinger tube runs behind. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted October 12, 2006 Report Share Posted October 12, 2006 Mine did too, so I simply mounted the silencer onto the other side of the mount which was enough to just push it off the frame. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 16, 2006 Author Report Share Posted October 16, 2006 I got some billit pipe hangers so maybe they will pull the pipe away from the frame. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 17, 2006 Report Share Posted October 17, 2006 I got some billit pipe hangers so maybe they will pull the pipe away from the frame. A few washers behind the hangers wouldn't hurt! Quote Link to comment Share on other sites More sharing options...
